Post by binarysurfer on Oct 29, 2013 19:04:59 GMT -6
Hahaha, thanks You two are awesome! I will have this puppy up and running in no time (during weekends)
Post by binarysurfer on Oct 28, 2013 20:17:18 GMT -6
I can always add models to my videos if it helps
Post by binarysurfer on Oct 28, 2013 20:15:07 GMT -6
I forgot to add that I replaced the spark plug too. As I began to take the carburetor apart, I noticed that the clip holding the needle in place is missing. As it turns out, someone has worked on it before me. So, I think I will have to see if replacing the clip solves the problem. Where is a good place to get replacement parts? I saw there is one bad site, shaggy.scooter..... Thank you
Post by binarysurfer on Oct 24, 2013 6:21:10 GMT -6
Awesome! I will do that this weekend thank you.
I will look into the valve spacing.
Post by binarysurfer on Oct 23, 2013 20:53:17 GMT -6
Hello and thank you for any help! I'm fixing a friends scooter that has sat for four years and only has 10 miles.
What I have done: -Replaced the battery -Changed the oil -Checked the air filter -Cleaned out the gas tank and gas line. Filled with 87 oct -Followed what alleypoop suggested in a different post, adjusted the carburetor mixture. It runs a bit longer on a leaner setting. Here is a short video of it starting, running on its own, then dying on its own. If I give it throttle, it usually dies. Sometimes, with throttle it will run for 30 seconds, then die.
Again, any help is greatly appreciated!
Post by binarysurfer on Oct 23, 2013 20:12:47 GMT -6
Hahaha! That's awesome!!
Post by binarysurfer on Oct 23, 2013 19:40:05 GMT -6
The Headless Horseman on a tight budget! lol
Post by binarysurfer on Oct 23, 2013 19:36:22 GMT -6
A "cool" "green" helmet?
Post by binarysurfer on Oct 17, 2013 11:28:07 GMT -6
The video was sped up about 3x or 4x normal, so essentially, he was scooting along very slowly. The child was in little danger.
Post by binarysurfer on Oct 15, 2013 15:58:31 GMT -6
That's really good projection mapping. It feels like it came from After Effects though. Post production editing and adding to the video.
Post by binarysurfer on Oct 15, 2013 15:41:18 GMT -6
That's where scooter babies come from! It's surprising to see that most of the construction is done my hand
Post by binarysurfer on Oct 15, 2013 15:36:00 GMT -6
Are you serious that it can drive a nail through a 2x4 at 200 yards 0.o
New here
by: binarysurfer - Oct 15, 2013 15:30:27 GMT -6
Post by binarysurfer on Oct 15, 2013 15:30:27 GMT -6
Cool! I have the same scooter, I just have to get it up and running. Welcome to the forums.
Post by binarysurfer on Oct 15, 2013 15:21:46 GMT -6
Nice! It looks a lot sleeker, like cruiser motorcycles compared to crotch rockets
Post by binarysurfer on Oct 15, 2013 15:19:15 GMT -6
Wow talk about minimalism! How does aerodynamics handle at high speeds?
