Post by simularity on Nov 8, 2013 1:57:04 GMT -6
Just a little step by step guide to renewing your piaggio/gilera 50 oil pump belt, often overlooked piece that plays an important role and should really be renewed every 3yrs or around 10k miles Right let's get down to it First start by removing the variator using a locking tool or a 'windy' gun, I prefer the locking tool method myself once the variator is removed just pull the starter bendix and remove it Next remove the two screws holding the oil pump(http://www.motoparts-superstore.com/scooter-parts/scooter-engine-parts/oil-pump.html) on, take note how the slot on the rear of the pump sits on the drive no need to remove the pipes or cable, just cable tie or tape it to one side out of the way Next undo the screw and remove the inner metal plate Next remove the thick spacer washer and the two cogs with the belt
Post by simularity on Nov 8, 2013 1:54:34 GMT -6
There are so many belt sizes it is best to check and see what is currently on it and then you can work from there. hehe
Post by simularity on Oct 31, 2013 0:24:49 GMT -6
Post by simularity on Oct 31, 2013 0:21:42 GMT -6
Congrats!
