YY250T-1
by: scoooter - Dec 1, 2013 18:23:15 GMT -6
Post by scoooter on Dec 1, 2013 18:23:15 GMT -6
Okay, I have the same bike, it is a 250 horizontal engine. Having similar issues when I take my hands off the handlebars...........wobble. It happens from 30-55 mph. It doesn't happen at 65 till speed decreases to around 55. No problems as long as I have my hands on the bars. Any ideas?
Post by scoooter on Nov 3, 2013 8:31:31 GMT -6
What is the switch on the right handle bar below the kill switch? It is yellow on my bike, push switch but has no effect on anything.
Post by scoooter on Nov 1, 2013 20:05:17 GMT -6
Got the new flasher today and all works now, turn signals and flashers. Thanks all for your help!
Post by scoooter on Oct 31, 2013 17:35:25 GMT -6
Thanks for the info. Mine is a Jonway and from what I've seen I think it is a Ranger?? I'll peek in and see if it is vertical or horizontal.
Post by scoooter on Oct 31, 2013 14:19:57 GMT -6
Mine has a plastic 3 connector female to the wiring harness. I can use one from the parts house that is male prongs and splice spade connectors to my pigtail to make it work but the correct one will arrive tomorrow. I'll try it and hope it solves the problem. BTW, I'm new to the site. I'm looking forward to it. As stated earlier I have the YY250T. Thanks for your help!
Post by scoooter on Oct 31, 2013 6:43:27 GMT -6
When I turn the key to start position they do not work either. The only way to light the turn signal lights is with the key fob, either remote start (stay on for a few seconds) or alarm (all four flashing). I checked the black (hot) and green (ground) wires going to the flasher and have 13.3 volts with the key in the on positijon. When I put the flasher on a battery and check the grey wire coming from the flasher it is a continuous 18+ volts. That seems weird. I have a new flasher coming, the parts store just had the generic flasher with spade connectors.
Post by scoooter on Oct 30, 2013 18:30:57 GMT -6
The turn signals light when you hit the key fob start button. They flash when you hit the alarm and the dash indicator lights flash with the alarm and come on solid when you hit the start on key fob. I have replaced the turn signal switch. The hazard switch on the right handle bar does nothing. I have a new flasher coming but don't think that will fix it. Any ideas?
