Post by mxmatt on Aug 30, 2018 23:25:17 GMT -6
Avon AM63 Viper Stryke 140/60-13 29
Post by mxmatt on Aug 30, 2018 22:48:27 GMT -6
So the majesty is treating you well? Hi Cyborg! It’s been a while! Thanks fir asking. The Majesty treated me amazing. Not a single problem the entire time I owned it. But I moved up to a Honda VTX 1800 in December 2016. 😂 I loved being on here back in my scooter days. Someday maybe I’ll get me another one. 👍🏻
Post by mxmatt on Dec 8, 2016 21:40:48 GMT -6
Sorry for the bump. Sold this scoot last month for $1100. It was hard to part with. Got me a Yamaha Majesty 400. I love it! Thought I would contribute this information to the sight.
2014 Roketa 250 R1-MC-54-250
Odometer: 6665 miles Notes: Services
Brake System
Every 4,000 miles or 12 months Notes: Inspect brake hoses, pipes and fittings for deterioration, cracks, damage or signs of leakage. Tighten as needed. Replace where required. Service History: 4229 miles - Nov 8, 2015 (Rebuilt front caliper, Sil-glyed causing cylinder to stick, cleaned and reassembled, new fluid) 1 miles - Jun 8, 2014 (New scooter. Replaced Chinese fluid with Honda Pro Brake Fluid; DOT 4 (front)) Crankcase Breather
Every 2,000 miles or 12 months Notes: Remove the crankcase breather hose plug from the hose and drain any deposits into a suitable container, then install the crankcase breather hose plug securely. Note: service more frequently when operated in rain, at full throttle, or after the scooter is washed. Service if the deposits level can be seen in the transparent section of the breather hose. Service History: 4589 miles - Dec 19, 2015 (Completely disassembled and cleaned crankcase breather system and air box. No detectable deposit build up in tube. ) 2001 miles - Sep 13, 2014 (Empty Repaired failure at valve cover) 1 miles - Jun 8, 2014 (New scooter) Final Drive Oil
Every 2,000 miles or 12 months Notes: Level Check: center stand, warm engine, stop engine, remove check bolt, add oil until it flows out. Torque: 9 ft/lbs Service History: 4585 miles - Dec 19, 2015 (SuperTech SAE 75w-90 Synthetic Blend) 2001 miles - Sep 13, 2014 (Amsoil Severe Gear SAE 75w90) 1 miles - Jun 8, 2014 (Valvaline Full Synthetic 75w-90. Replaced Chinese oil.) Wash Exterior
Every 1 months Notes: Service History: 6284 miles - Oct 5, 2016 (Soap and water, compressed air dry) 5689 miles - Sep 18, 2016 (Soap and water, compressed air dry) 5344 miles - Aug 27, 2016 (Soap and water, compressed air dry) 5015 miles - May 30, 2016 (Soap and water, compressed air dry) 4650 miles - Apr 26, 2016 (Soap and water, compressed air dry) 4519 miles - Dec 16, 2015 (Soap and water, compressed air dry) 4339 miles - Nov 13, 2015 (Soap and water, compressed air dry) 4129 miles - Aug 1, 2015 (SuperTech Wash & Wax) 3540 miles - Mar 4, 2015 (Soap and water, compressed air dry) 3048 miles - Oct 23, 2014 (Soap and water, compressed air dry) 2509 miles - Oct 3, 2014 (Soap and water, compressed air dry) 1455 miles - Aug 26, 2014 (Soap and water, compressed air dry) 918 miles - Aug 4, 2014 (Soap and water, air dry on ride) Brake Fluid
Every 6,000 miles or 24 months Notes: Torque screw: 1.1 ft/lbs DOT 4 brake fluid Fill to upper level Service History: 5000 miles - May 30, 2016 (Rear: Replaced Chinese fluid with Pro Honda DOT 4 Brake Fluid) 4229 miles - Nov 8, 2015 (Replaced fluid in front brake, topped off rear. ) 1 miles - Jun 8, 2014 (Front: Replaced Chinese fluid with Pro Honda DOT 4 Brake Fluid) Brake Pad Wear
Every 2,000 miles or 12 months Notes: Check pads for wear. Service limits: Front 3.5 mm Rear 4.0 mm Service History: 6665 miles - Oct 22, 2016 (Replaced pads with original style. No more rattle. Pads were 50% worn. ) 4746 miles - Apr 30, 2016 (Replaced Rear Pads Pads wore unevenly Slides were dry and crusted from old muffler touching caliper. Front Pads within service limits. Used pads without slide guide, makes rattling/knocking noise against caliper.) 4229 miles - Nov 8, 2015 (Within service limits) 2001 miles - Sep 13, 2014 (Within service limits.) 1 miles - Jun 8, 2014 (Original pads front and rear. Brand new.) Clutch Shoe Wear
Every 4,000 miles or 24 months Notes: Service Limit: 0.5 mm Service History: 4058 miles - Jul 29, 2015 (First Kick - Ray Sikes Within service limits ) 1 miles - Jun 8, 2014 (Origional clutch, brand new) Drive Belt
Every 12,000 miles or 36 months Notes: Replace at 12,000 miles Service History: 1 miles - Jun 8, 2014 (Gates Powerlink 918 22.5 (origional)) Drive Belt Check
Every 4,000 miles or 12 months Notes: Check/Service every 4000 miles Service History: 5689 miles - Sep 18, 2016 (Within service limits but showing signs of wear CVT/Clutch cover gasket damaged. Needs replaced. ) 4058 miles - Jul 29, 2015 (First Kick - Ray Sikes Within service limits ) 1 miles - Jun 8, 2014 (New Scooter) Engine Idle Speed
Every 2,000 miles or 12 months Notes: Inspect and adjust idle speed after all other engine maintenance items performed and when engine is warm. IDLE SPEED: 1500+/-100 rpm Service History: 5341 miles - Aug 27, 2016 (Idle was low, adjusted to1700) 4050 miles - Jul 9, 2015 (First Kick - Ray) 3369 miles - Nov 6, 2014 (Idle was running at 1900 RPM. Adjusted to 1500 RPM) 2001 miles - Sep 13, 2014 (Idle was at 1000rpm. Adjusted it to 1500rpm on tach. ) 1 miles - Jun 8, 2014 (New scooter) Engine Oil Change
Every 500 miles or 6 months Notes: Initial change at 600. Honda Manual recommends every 4000 miles after that (PRO Honda HP4) API service classification SG or higher. JASO T 903 standard MA Viscosity 10w30 Oil capacity at draining: 1.2 US qt Strainer Cap Torque: 14 ft/lbs Service History: 6421 miles - Oct 8, 2016 (Castrol GTX 4T SAE 10W-40 Motorcycle Oil (Favorite Performance) Cleaned filter screen 10ml Liqui Moly) 5900 miles - Sep 23, 2016 (Castrol GTX 4T SAE 10W-40 Motorcycle Oil (Favorite Performance) Ran 1oz Seafoam for last 10 mi Cleaned filter screen 10ml Liqui Moly ) 5884 miles - Sep 22, 2016 (Walmart SuperTech SAE 20W-50 (dumped b/c I didn't like performance) 10ml Liqui Moly ) 5313 miles - Aug 26, 2016 (Castrol GTX High Mileage SAE 10W-40 Cleaned filter screen 10ml Liqui Moly) 4746 miles - Apr 30, 2016 (Castrol GTX SAE 10W-40) 4127 miles - Aug 1, 2015 (Castrol GTX SAE 10W-40 Cleaned filter screen 10ml Liqui Moly) 3602 miles - Apr 11, 2015 (Castrol 4T Motorcycle Oil 10W40 10ml Liqui Moly) 3048 miles - Oct 23, 2014 (Mobil 1 Full Synthetic 0w40 10ml Liqui Moly) 2568 miles - Oct 5, 2014 (Mobil 1 Full Synthetic 10w40) 2001 miles - Sep 13, 2014 (Mobil 1 Full Synthetic 15w50 10ml Liqui Moly) 1455 miles - Aug 26, 2014 (Mobil 1 Full Synthetic 15w50 Filter cleaned 30ml Liqui Moly) 382 miles - Jul 4, 2014 (Walmart SuperTech 20w50 Cleaned filter, Looked good. 30ml Liqui Moly. ) 79 miles - Jun 21, 2014 (WalMart SuperTech 20w50 30ml Liqui Moly) 1 miles - Jun 8, 2014 (Castrol GTX 20w50) Engine Oil Strainer Screen
Every 4,000 miles or 24 months Notes: Clean the oil strainer Torque: 14 lbf•ft Service History: 5313 miles - Aug 26, 2016 (Some minor debree ) 1455 miles - Aug 26, 2014 (Nino debris collected. ) 1 miles - Jun 8, 2014 (New Scooter. ) Fuel Line Inspection
Every 8,000 miles Notes: Check fuel lines for deterioration, damage or leakage. Replace fuel lines or filter if necessary. Service History: 5689 miles - Sep 18, 2016 (Replaced Fuel Filter Lines all looked good) 1 miles - Jun 8, 2014 (New Scooter) Nuts, Bolts, Fasteners
Every 4,000 miles or 24 months Notes: Check that all chassis nuts and bolts are tightened to correct torque values. Check all cotter pins, safety clips, hose clips and cable stays. Service History: 4050 miles - Jul 9, 2015 (First Kick - Ray) 1 miles - Jun 8, 2014 (All nuts, bolts, fasteners removed, tightened, loctite applied and silicone covered. ) Radiator Coolant
Every 8,000 miles or 24 months Notes: Replace every 2 years or 12,000 miles. Check coolant level in reserve tank with engine running at normal operating temperature. Should be between "UPPER" and "LOWER" level lines while on center stand. Service History: 4650 miles - Apr 26, 2016 (Replaced with Prestone 50/50) 1 miles - Jun 8, 2014 (Replaced Chinese fluid with Prestone 50/50 coolant) Replace Air Cleaner
Every 6,000 miles or 24 months Notes: Replace the element in accordance with the maintenance schedule or anytime it is excessively dirty or damaged. Honda manual recommends replacement after 12,000 miles. Service History: 4589 miles - Dec 19, 2015 (New stock air filter from KM warranty ) 1 miles - Jun 8, 2014 (New scooter) Side Stand
Every 8,000 miles or 24 months Notes: Check for smooth operation. Engine should stop if stand is lowered. Inspect side stand switch. Service History: 5015 miles - May 30, 2016 (Operating properly. Lubrication acceptable. No switch. ) 1 miles - Jun 8, 2014 (Bolt removed, loctite applied, white lithium grease applied. ) Spark Plug
Every 4,000 miles or 24 months Notes: Check the insulator for cracks or damage, and the electrodes for wear, fouling or discoloration. Replace the plug if necessary. If the electrode is contaminated with carbon deposits, clean the electrode using a spark plug cleaner. For extended high-speed riding: DPR8EA-9, (NGK), X24EPR-U9 (DENSO) Gap: 0.031-0.035 Torque: 13lbf•ft Service History: 4587 miles - Dec 19, 2015 (New NGK DPR8EA-9 Gapped at .033 Torqued to spec) 1 miles - Jun 8, 2014 (New Scooter) Steering Head Bearings
Every 4,000 miles or 24 months Notes: Raise front wheel and check that handle bar moves freely from side to side. Note any unevenness, binding or vertical movement. Service History: 4050 miles - Jul 9, 2015 (Within service limits) 1 miles - Jun 8, 2014 (New scooter) Suspension
Every 4,000 miles or 24 months Notes: Check action of forks using front brake. Check for signs of leaks, damage or loose fasteners. Repeat for rear shocks. Check for worn engine mounting bushings. Service History: 4127 miles - Aug 1, 2015 (Front showing some signs of oil leakage. Rear is fine. Bushings fine. ) 1 miles - Jun 8, 2014 (New scooter - Original fluids) Throttle Operation
Every 8,000 miles or 24 months Notes: Check for any deterioration or damage to the throttle cables. Check the throttle grip for smooth operation in all steering positions. If necessary, lubricate the throttle cables and lubricate the throttle grip housing. For cable lubrication: Thoroughly lubricate the cables and their pivot points with a commercially available cable lubricant or light weight oil. Throttle Free Play: 2-6 mm Service History: 5341 miles - Aug 27, 2016 (Adjusted to within specs) 1 miles - Jun 8, 2014 (New scooter) Valve Clearance
Every 4,000 miles or 24 months Notes: Inspect and adjust valve clearance while the engine is cold. Timing Hole Cap and Adjusting Hole Cap: Torque 4.3 lbf•ft Service History: 5689 miles - Sep 18, 2016 (Within service limits. No adjustment needed.) 1 miles - Jun 8, 2014 (New scooter) Wheels/Tires
Every 400 miles or 12 months Notes: Check tire pressure with accurate gauge. See tires for limits. Manual: Front 25, Rear 29 With passenger, Front 25, Rear 36 Check tires for cuts, embedded nails or damage. Check for trueness. Measure tread death. Service Limit: 1.5 mm Service History: 6419 miles - Oct 8, 2016 (25 PSI FT 29 PSI RR Tread within service limit) 5689 miles - Sep 18, 2016 (25 PSI FT 29 PSI RR Tread within service limit) 5344 miles - Aug 27, 2016 (25 PSI FT 29 PSI RR Tread within service limit) 5015 miles - May 30, 2016 (25 PSI FT 29 PSI RR Tread within service limit) 4585 miles - Dec 19, 2015 (25 PSI FT 29 PSI RR) 4129 miles - Aug 1, 2015 (25 PSI FT 25 PSI RR Tread looks good. ) 3500 miles - Mar 2, 2015 (25 LBS FT 29 LBS RR) 3100 miles - Oct 28, 2014 (Replaced original rear tire with Avon AM63 Viper Stryke 140/60-13 29 PSI FT) 2963 miles - Oct 22, 2014 (25 PSI FT 29 PSI RR) 2391 miles - Oct 2, 2014 (25 PSI FT 36 PSI RR) 2001 miles - Sep 13, 2014 (26 PSI FT 30 PSI RR) 1455 miles - Aug 26, 2014 (25 PSI FT 29 PSI RR) 1186 miles - Aug 14, 2014 (29 PSI FT 30 PSI RR) 721 miles - Jul 28, 2014 (29 PSI FT 29 PSI RR) 1 miles - Jun 8, 2014 (New scooter) Replace Fork Oil
Every 12 months Notes: Service History: Repairs:
Air Box Broken 6419 miles - Oct 8, 2016 Notes: Upper connectin flange broken, lower connecting flange bolt missing. Replaced lower bolt. Will repair broken flange ASAP. Head Gasket 4650 miles - Apr 26, 2016 Notes: 11-1-14 during 30 mile round trip freeway ride in cool evening air, coolant reservoir spewed coolant and temp gauge redlined immediately. Limped last 5 miles home filling with ice water from convenience stores. Replaced coolant at home and this sequence repeated itself over and over. No amount of burping coolant would stop it from overheating. First few miles from cold engine seemed fine, but eventually coolant would expel from overflow tank. Since replacing head gasket and burping system it runs great and stays cool even in the dead of the AZ summer heat. Took me 15 months to actually accept that a five month old scoot could actually blow a head gasket. I tried literally everything the internet advisors put forth before changing it out. Purchased gasket on eBay for $8. Muffler (Warranty) 4600 miles - Jan 30, 2016 Notes: Original sounded like a can of rocks when shaken. Stated rattling after a ride on a poorly maintained road and then a short distance on a dirt road with some washboard 2 months after purchase. Thermostat 3369 miles - Nov 6, 2014 Notes: Original thermostat was not opening and causing overheating. Update: original thermostat was tested and working fine. Still over heating even with new thermostat. Ultimately it turned out to be the head gasket. Replaced Broken Horn 2762 miles - Oct 11, 2014 Notes: Replaced Broken horn after water damage during summer rain storm. Horn 382 miles - Jul 4, 2014 Notes: Fixed broken wires. Horn operational now. You
Post by mxmatt on Oct 21, 2016 1:56:19 GMT -6
Starter motor is going away,,,, but an old farmer trick,,, and don't laugh I've seen this trick work on many occasions ,,, get a small hammer and give the side case of the starter a sharp rap,,, my son built a hotrod gti vw,, then his starter started to go away,,, I gave it the rap,,, it literally lasted till he sold the car Is a starter affected by the engine temperature? I'll give it a good wack anyway.
Post by mxmatt on Oct 20, 2016 20:47:25 GMT -6
I'm having a strange starting issue with my scoot. Essentially it seems like it is progressively more difficult for the starter to turn the motor over in order to start. At first start of day it starts no problem. I do a lot of short traveling with stops for about a half hour or so and as I go to start it with each progressive stop, it seems as though the starter labors harder and harder and sometimes has to be pushed more than once to get it to turn over. I can usually coax it, but today for the first time it refused. I let the bike cool down for a while and eventually I got it started. It doesn't appear to be battery related.
Has anyone experienced this?
I'm wondering if it is valve related. If they need adjusted, can they prevent the motor from turning over if the engine temp is at operating temp vs cold?
Post by mxmatt on Oct 1, 2016 19:22:59 GMT -6
You can order it from many "Scooter Parts" stores here on line or I think you can still order them directly from Roketa.com .... There really not to hard to find. I haven't found one on any site yet. Am I missing it?
Post by mxmatt on Sept 28, 2016 17:46:10 GMT -6
Hi guys!
I'm having trouble finding this part for my scoot. I have the scooter pictured in my profile. It a Rockets MC 54 250. Any help would be appreciated.
Post by mxmatt on Aug 30, 2016 10:17:29 GMT -6
Mx youre the Suzuki dr guy correct? I'm not. Must have me confused with another member. I'm a Honda guy, but I love my YY250T!
Post by mxmatt on Aug 29, 2016 13:16:50 GMT -6
NICE good deduction!!! There's a piston right there What up Cyborg? Piston? Not following you.
Post by mxmatt on Aug 29, 2016 0:45:48 GMT -6
So the screw clamp on the hose connected to the water pump broke and coolant had been weeping out for who knows how long. Replaced it, filled it up, burped it, problem solved. Fan working fine.
Post by mxmatt on Aug 22, 2016 17:12:31 GMT -6
Hey guys! Been a while. Still loving my 250. Especially since I replaced the head gasket that WAS causing the overheating problem.
Quick question: My fan motor stopped working Ll of a sudden today. Not sure where to start trouble shooting. My bike is a 2014 Jonway YY250T (Honda Clone, Radiator up front, 5300k miles). Where do I start or should I just replace the temp sensor and fan all together given the mileage?
Post by mxmatt on Apr 30, 2016 22:51:28 GMT -6
I saw a modification where someone took a car headrest and modified it to the scooter seat. worked great and cost was minimul You have a picture of this?
Post by mxmatt on Apr 30, 2016 21:14:53 GMT -6
Don't know what happened but NO when I opened the thead it only showed the 1st page and I responded to that page. It did not show that it was novel and it had 5 more pages. ![(rofl)](//storage.proboards.com/3059616/images/UdZWLQdgsIWX5Li7LQdC.gif) Why do I feel the urge to come up with some "Rich like" smart remark? ![???](//storage.proboards.com/3059616/images/uQfospbezE7IcMUG1AtY.gif) ? Thanks for all you help on this thread.
Post by mxmatt on Apr 30, 2016 20:14:46 GMT -6
Thanks JR. Rich was sooooo helpful to me. He went way too soon!
