1985 ch150D Honda elite
Post by oilee on May 27, 2014 18:18:52 GMT -6
If a guy was looking to buy a 150cc scooter, what would you buy? Chinese , Japanese ? Based on affordability,reliability,getting parts, upgrading with motor mods.
Lee
Post by oilee on May 24, 2014 22:26:36 GMT -6
My vote is to paint em black and put a red stripe. Looks cool.
ORRRRRR
black with silver stripe.
Post by oilee on May 24, 2014 22:09:58 GMT -6
That definitely shed a bit of light on the subject. I got that filter from my local O'reilly auto parts store. I also bought a little vac tube connector. fit great and tie strapped it down to my coolant hose. I'm into it about $12 dollars.
Lee
Post by oilee on May 24, 2014 21:20:27 GMT -6
Post by oilee on May 24, 2014 14:46:23 GMT -6
Post by oilee on May 24, 2014 14:45:30 GMT -6
If a guy was going to remove this , would he just put a small air breather(filter) on the tube coming out of the crankcase. And just plug the hole on the air intake before the carb? Will i have to adjust the carb.
Post by oilee on May 24, 2014 14:32:05 GMT -6
OK, i got it all unhooked, and removed and plugged up the proper items.
Running good, no probs.
Post by oilee on May 23, 2014 17:59:28 GMT -6
Thats what it's all about. Learning , helping , sharing .
Post by oilee on May 23, 2014 16:45:53 GMT -6
Yes,Exactly how i was starting to see it. Tell me , can you run these engines with the other hoses un hooked and pluged? Example , the one going from the middle of the carb to the bottom of the air cut off valve. And the one going from the intake manifold to the vac nipple on the air cut off valve.
Lee
Post by oilee on May 23, 2014 14:30:19 GMT -6
The acv on mine has two vac. hoses. One goes to the intake manifold and the other goes to my gas tank petcock. The petcock on my scoot has a vac hose connected to it, it works off of vac. there is a valve on it that lets the fuel go to the carb once vac is applied.
I'll start unpluging, and plugging the system up and see if i see a difference.
Lee
Post by oilee on May 22, 2014 18:57:41 GMT -6
Rich , i really appreciate you taking the time to work through this with me. I'm just mechanical enough to get myself in trouble sometimes. I sure like learning things about this scoot.
It's a 85 150 elite.
Post by oilee on May 22, 2014 18:43:48 GMT -6
Yes, that is the carb i have. the two open nipples on that acv i think are vac, am i correct? The one facing to the right goes to my fuel petcock no prob there. The one facing down, its connected to the nipple on the intake manifold on my scoot. Is this correct? should i plug that up at each end ?
Post by oilee on May 22, 2014 18:35:27 GMT -6
It looks like to me that the engineers that designed this system should have spent there time doing something more constructive.
What are you gonna do.
My scoot is hooked up like the illustration except for the hose that goes to the intake manifold. It is hooked up to the purge control valve but is routed over close to the carb and just tucked away and not hooked to anything.
My concern is the nipple on the intake manifold has a hose on it. and it goes to the air cut off valve. i think its a vac line , is this correct?
Post by oilee on May 22, 2014 17:42:16 GMT -6
Sorry about this , i have never used photobucket and im having a tough time getting photos on here. Its all on my side here. Im not as good with computers as i should be.
So, the line right above your #1 is coming out of the purge control valve and i think that is suppose to go to the intake manifold but it was unhooked and tucked away hiding. Now the gray hose above that one coming down from the top of the pic. going from left to right and then turning down and turns to a black hose goes directly in to the canister coming from the fuel tank, that is how the book shows it also. #2 goes from the purge control valve to the air cleaner box. #3 is indeed the canister.
Post by oilee on May 22, 2014 16:56:01 GMT -6
