Post by cheapscooterguy on Oct 6, 2011 18:32:46 GMT -6
I have a 2008 lambretta UNO 150. Really is Adly hammerhead 150 Thunderbike I was cruising at 50 mph when scoot made strange noise and engine stopped working. Was able to coast to stop. Drive belt is fine, getting spark to engine and gas in carb. Any ideas on what to do? New to forum thanks for your time
Mike- cheapscooterguy
Vespa Specialist
Post by Kaveman on Oct 6, 2011 19:57:09 GMT -6
compression ? Valve gap adjustments ? will
Post by cheapscooterguy on Oct 6, 2011 23:23:13 GMT -6
I'm a novice at working on scooters. How would I do the compression test and valve adjustment? My battery went dead trying to start , got a charger to recharge
Retired Army War Veteran Living The Good Life
Post by trancebear on Oct 6, 2011 23:37:06 GMT -6
There are several videos on YouTube about how to do both things. great resource. I learned valve adjustments and many other things from there.
Post by gatekeeper on Oct 7, 2011 0:16:01 GMT -6
My Adly did that a couple of weeks ago. Once I got it home I pulled the sparkplug out and placed my finger over the hole and turned the motor over with the electric starter. Felt no compression while doing this. Pulled the valve cover off and found one of the exhaust valves stuck open.
It is currently at the dealer to find out the extent of the damage and to see how well Adly's warranty is going to work.
Post by cheapscooterguy on Oct 7, 2011 0:33:45 GMT -6
Thanks for info. Will try compression and check valves and get back to you.
Post by sprocket on Oct 7, 2011 16:03:29 GMT -6
Have you tried to kick start the engine to see if it will roll over???
Post by cheapscooterguy on Oct 9, 2011 12:48:59 GMT -6
Yes I tries kick starting. No luck
Post by sprocket on Oct 9, 2011 13:20:48 GMT -6
I would set the valve gaps and then check the compression...
