Post by ger42 on Apr 20, 2012 12:34:42 GMT -6
I have just about 200 miles on my 5 month old Magnum. This will be the 3rd time I adjust the chain, This time the the slack is big. Should I forgo the tightening and get a new chain? Adjusting the chain is a pain in the butt I'd like to reduce the number of adjustments I have to make. I won't ride it until I adjust it or get a new chain. Your thoughts will be welcomed. To get the size for a new chain do I take the old one off and measure it?
Post by NoJoy on Apr 20, 2012 17:43:44 GMT -6
Hey Ger, when I picked up my Magnum from Jim it need a new chain. As I remember he ordered a long chain from Yamaha and measured and cut it from that. I think he also added a half link to get it to it's minimum possible length. I would suggest you give him a shout just to double check.
ed
Post by Alleyoop on Apr 20, 2012 17:53:21 GMT -6
All you have to do is count the pins and get one that has at least the same number of pin counts or greater. Most chains will have more pin count so you will have to cut to length so also get a chain breaker. Alleyoop
Post by mike6736 on Apr 20, 2012 18:56:18 GMT -6
Ger....Do not put the same type of chain back on it or you will have the same problem. Take that old chain off go get a motorcycle chain for it, I am leaning to a o=ring type. That chain that is on there now can be purchased in any farmers supply and most haedware stores. They use the chino chains on bailers and other farm machines that normally have loaded adjusters on them. It is so cheap you get a 10 ft long chain for $28... Also make sure you have the rear sproket aligned a good as you can, change the spacer if you have to as it will cause you a lot of problems
Mike
Post by royldoc on Apr 21, 2012 0:55:59 GMT -6
How do the sprockets look? They may be wearing out a little. Is it possible the adjustments are slipping? Is The chain out of alinement? Or just cheap chain? I have a little over 1k miles on mine and only adjusted the chain once. It still has about 1/2" slack. I keep it lubricated good also. But will replace it with better chain.
Roy
Post by jcamaro on Apr 21, 2012 11:23:54 GMT -6
I can tell you this when we ran O-ring chains it wore out the sprockets quicker on a two wheel bike same for the X chain.I have PM'ed you ger42 can you read it please
Post by Alleyoop on Apr 21, 2012 12:28:28 GMT -6
I disagree, the reason chains were out sprockets on two wheels is that the sprockets have no play in or out whatsoever. So not haveing any play the front and rear sprockets have to be RIGHT on otherwise the chain will be rubbing on the sides of the sprocket teeth and wearing them out. Alleyoop
Post by mike6736 on Apr 21, 2012 12:33:40 GMT -6
Yupper...That is why on the trike when the chain is loose you can really feel it and hear it if you are not right on, I have found close is not good enough
Mike
Post by ger42 on Apr 28, 2012 5:49:17 GMT -6
Sprockets look good and does too. I went to Cycle Gear for a chain guy aid my chain looked good why replace? I told him about the streaching. Too bad he didn't have the size I needed. Yahama wouldn't return my calls I guess I'll have to order online.
Post by ger42 on Apr 29, 2012 19:23:02 GMT -6
Sprockets look good and does too. I went to Cycle Gear for a chain guy aid my chain looked good why replace? I told him about the streaching. Too bad he didn't have the size I needed. Yahama wouldn't return my calls I guess I'll have to order online. Went in Saturday and guess what they had 2 on the shelf. Both of them had been there when I was in the other day. Tuesday I'll try to get it back on the road.
Post by mike6736 on Apr 29, 2012 23:13:00 GMT -6
Just go to the Yamaha shop with the chain they will have one
Mike
Post by ger42 on May 2, 2012 14:50:38 GMT -6
Okay I got the new chain cut and fitted but I screwed up the rivet on the link. Waiting for a new link one that clips on.
Post by mike6736 on May 2, 2012 15:51:23 GMT -6
what kind did you end up getting Ger?
Post by ger42 on May 10, 2012 15:16:49 GMT -6
Chain is a DID Xchain. Got it on this afternoon and then the rain started. Garage is too warm to work in when he door is closed. Tomorrow it's tighten it up and get it square. I'm sure some choice words will be flowing tomorrow in Plantation, FL.
Post by mike6736 on May 10, 2012 21:01:53 GMT -6
Was nice here today Ger, I went out and pulled the fuel trottle out of the Magnum. Have to pull it to the front and out, tied a cor to it so can pulle the new in, will go in the morning and see if I can find one. Probely a standard 250 cable but they can match it up or if I have to I can order one
Mike
