Post by necorum on Apr 24, 2013 0:44:00 GMT -6
1,950 miles on it.
I will take it apart after school tomorrow if weather permits.
Post by Alleyoop on Apr 24, 2013 0:47:12 GMT -6
cool because with the restrictions off it should move out pretty good. will check your thread tomorrow. Alleyoop
Post by necorum on Apr 24, 2013 0:49:56 GMT -6
all vids are now public and it does have the washer on the variator. The pics of the exhaust pipe. was there a restriction there before i end up buying an exhaust #75 jet from the looks of a pic i took earlier today.i didnt check the jet size ugh
Post by Alleyoop on Apr 24, 2013 0:52:31 GMT -6
Also take the carb off and maybe the cable is also restricted with that stopper that you pointed out. But you won't know until you take the carb off JUST FROM THE one side if you can tilt it and twist the throttle wide open and see HOW FAR IT PULLS THE SLIDER UP. It may not pull the needle all the way out of the Defuser and Main jet because of the stopper. Alleyoop
Post by necorum on Apr 24, 2013 1:04:39 GMT -6
that thing in the pic isnt on my carb. its on the other side of the engine by the flywheel.
Post by Alleyoop on Apr 24, 2013 1:22:14 GMT -6
Cool take the washer out of the Variator that will give you some top end right off the bat. ;D What does that open or close or is that for your brakes? Alleyoop
Post by necorum on Apr 24, 2013 8:38:44 GMT -6
It goes to the engine and connects to the throttle cable only It is on the right side of the engine. Carb throttle cord is on the left? Wait I think it goes to the oil pump? My main jet is 45 or 47.5 according to the assembly manual. I will take the carb off and bring it inside to look at. So how do you remove the oil line. That is my only problem getting the carb off. Air intake pics Intake smells like gas ....... and once again has some in the box
Post by Alleyoop on Apr 24, 2013 18:39:09 GMT -6
Yes, see that small tube inside which the opening is looks like 3/8 of an inch in ID. Not much air goes through there. If you main jet is 45 WOW!! that is small, so if you put in a bigger jet then take that small tube off if you can to allow more air to feed the bigger jet. Alleyoop
Post by Alleyoop on Apr 24, 2013 18:44:44 GMT -6
I cannot see the OIL line but it should either screw on or the hose just clamped onto a connector on the carb. Now you will have to plug that oil hose so oil does not drain out. Alleyoop
Post by necorum on Apr 24, 2013 19:42:07 GMT -6
New jet is needed, I already modded the airbox........ removed the tube and widened the hole. Removed the variator restriction.
Post by Alleyoop on Apr 24, 2013 20:49:17 GMT -6
Very Cool, without the Washer in the Variator you should get better top end right off the get go. Alleyoop
Post by necorum on Apr 24, 2013 21:00:20 GMT -6
WOT kills the engine though now. Prob need to upjet.
Post by Alleyoop on Apr 24, 2013 21:04:22 GMT -6
Yep now to much air not enough MOJO JUICE So for now you can tape up part of the air tube so you don't run lean until you upjet the carb. Alleyoop
Post by necorum on Apr 24, 2013 21:05:30 GMT -6
cool will do, I will let you know how it runs after i get back fro college tomorrow.
Post by Alleyoop on Apr 24, 2013 21:06:40 GMT -6
Get some duct tape and tape up 1/3 of the hole and try that, if still tape up a little mor of it and so on. YOU DO NOT WANT TO RUN LEAN you will damage the motor. Alleyoop
