lights
by: scootdode - Oct 24, 2014 21:19:19 GMT -6
Post by scootdode on Oct 24, 2014 21:19:19 GMT -6
Used light tonight and worked well am very happy i can see woho
lights
by: scootdode - Oct 24, 2014 14:48:26 GMT -6
Post by scootdode on Oct 24, 2014 14:48:26 GMT -6
Will is if daughter know how to do pictures
lights
by: scootdode - Oct 24, 2014 13:16:46 GMT -6
Post by scootdode on Oct 24, 2014 13:16:46 GMT -6
2014 pst150-c hay was able to run the wire from stator to a 2nd regulator got the 12volts out light is working good put a dimmer switch on it to.
lights
by: scootdode - Oct 23, 2014 20:24:35 GMT -6
Post by scootdode on Oct 23, 2014 20:24:35 GMT -6
Is there a way to put a regular on for that wire on the stator to get the dc voltage I would need to run the lights that are added
lights
by: scootdode - Oct 23, 2014 20:16:49 GMT -6
Post by scootdode on Oct 23, 2014 20:16:49 GMT -6
Light of a retro scooter big chrome light 1 bulb putting it on my pst150c icebear trike for more light have the x wire from stator but puts out ac voltage would like to have it run that light and any that may add later
lights
by: scootdode - Oct 23, 2014 16:47:59 GMT -6
Post by scootdode on Oct 23, 2014 16:47:59 GMT -6
Have 11pole stator one wire not being used can I add a regulator and get the dc voltage i need to run the lights I am adding.
Post by scootdode on Oct 22, 2014 19:48:40 GMT -6
OK have 3100 on it now had to replace the chain.must have been in bad shape for some time it is a lot smoother rideing now.
Post by scootdode on Oct 9, 2014 12:16:52 GMT -6
I was luck and had a engine from a parts bike and that is where the head and the start clutch come from.repaired the ground wire on the stator
Post by scootdode on Oct 8, 2014 18:27:39 GMT -6
Good you got it going have fun now and ride ride ride
Post by scootdode on Oct 8, 2014 18:21:00 GMT -6
I got the ice bear 150cc trike Aug 8 2014 now have 2800miles on it i like it but have had some problems with it the plug broke off in head stator ground wire would melt when trying to start it found that there was no ground wire from engine to frame than the Allan screws broke off in start clutch running good now hope it stay that way for a long time now had to tighten the hubs up today took a lot of vibration out
Post by scootdode on Oct 8, 2014 5:17:16 GMT -6
Jam nut on my 150cc no more trouble
stator
by: scootdode - Oct 7, 2014 11:42:54 GMT -6
Post by scootdode on Oct 7, 2014 11:42:54 GMT -6
Ok will put one to engine thanks for your help
stator
by: scootdode - Oct 7, 2014 5:27:40 GMT -6
Post by scootdode on Oct 7, 2014 5:27:40 GMT -6
Ok - on battery 2number 10 to frame at regular should 1go to engine
stator
by: scootdode - Oct 7, 2014 5:01:17 GMT -6
Post by scootdode on Oct 7, 2014 5:01:17 GMT -6
Ice bear pst150c can not find ground wire from engine to frame do I need to put one on 2014 mod
stator
by: scootdode - Oct 6, 2014 20:00:22 GMT -6
Post by scootdode on Oct 6, 2014 20:00:22 GMT -6
May need to put heavier ground wire on from engine to frame than
