yy250t fuses?
by: cordinb - Feb 9, 2015 10:14:23 GMT -6
via mobile
Post by cordinb on Feb 9, 2015 10:14:23 GMT -6
yy250t fuses?
by: cordinb - Feb 8, 2015 19:50:53 GMT -6
via mobile
Post by cordinb on Feb 8, 2015 19:50:53 GMT -6
just a quick question, which type of fuses should I use? right now I am using all type 10.
the reason I ask is, when I turn the key my dashboard does nothing. I was doing reading and trying to understand why and I heard to replace my fuses. anyway did that, same problem occurs most of the time. It's rare that it works.
Post by cordinb on Jan 31, 2015 22:02:07 GMT -6
Hi again! The kill switch on my yy250t only seems to prevent the scooter from turning on and lacks the ability to kill the engine if in an emergency.
When i have the kill switch on (the crossmark over the head set symbol) the engine won't start or do anything but light up the clock on the dash. Now when i have the switch off, my scooter starts instantly. However once the scooter is on and when i flip the kill switch on, nothing happens.
Post by cordinb on Jan 11, 2015 22:52:34 GMT -6
I'm not sure if this is the correct category to post this but I was curious what everyone's worst crash/accident while being on a scooter?
Me: Two weeks ago my yy250t hydroplaned and I was flown off at 50mph on a 35, causing my right clavicle to snap in half and bruised my right side of my ribs where as I couldn't breath for a week. My helmet, which became horribly banged up, saved my head. The scooters right side is damaged, not too bad though... nothing I can't put back together with simple fiberglass work. Still have some wraps and stuff on me atm which are expected to come off in 6 more weeks. A week after all this happened, I'm still scootin' my broken self everywhere
Share your stories!
Post by cordinb on Jan 7, 2015 4:57:14 GMT -6
Ok so it's time to change the gear and motor oil. I know which type to use as they are stickered on there but I have a few questions.
How much motor oil do I use to fill it up?
Where is the drain and fill slot for the gear oil?
and how much gear oil do I use?
Keep in mind I have a YY250T Jonway
Appreciate the help like always
Post by cordinb on Jan 5, 2015 9:36:03 GMT -6
Post by cordinb on Dec 30, 2014 19:56:34 GMT -6
Sorry nobody answered but it's hard to tell what will work on which bikes. The vendor is often vague and there's variation on the bikes. I would just make sure the vendor takes returns. I do think those seats would work, you have the reflex clone so they should fit. But we've all been burnt by parts that won't fit our scooters so we weren't ignoring you, we just didn't want to give you bad advice. I understand. I'll have hope for the seat at least
Post by cordinb on Dec 27, 2014 13:06:59 GMT -6
Post by cordinb on Dec 27, 2014 11:33:17 GMT -6
Ok I believe I fixed it all, so far no leak and the engine is doing ok with staying cool
Post by cordinb on Dec 26, 2014 8:54:26 GMT -6
Where does the tube coming from the cooling tank go to though?
Post by cordinb on Dec 26, 2014 2:47:09 GMT -6
By the way, what is this thing? It looks like a black plastic oil drum with two connections on the bottom, which have a tube in one connected to the radiator cap area and another which connects somewhere to the engine (I think). The top part of it seems to not be connected anywhere. Is this where the mysterious tube homes to?
Post by cordinb on Dec 26, 2014 1:37:47 GMT -6
Post by cordinb on Dec 26, 2014 1:34:13 GMT -6
Is there a T just like the 150cc scooters have with the vacuum lines? I think so.
Post by cordinb on Dec 26, 2014 1:28:47 GMT -6
Post by cordinb on Dec 25, 2014 19:30:07 GMT -6
