Slight Bog
by: bohman731 - May 20, 2015 14:36:16 GMT -6
Post by bohman731 on May 20, 2015 14:36:16 GMT -6
Hey guys, so I am having a small bogging down issue. It only happens when I am stopped and I JUST start to accelerate it bogs just for a second and then accelerates through the whole powerband fine. Sometimes when I am stopped and blip the throttle it will die if I dont nurse the throttle for a second.
150cc GY6
Post by bohman731 on May 10, 2015 10:01:42 GMT -6
Alright so after I get the gear pulled how do I put it back to where it exactly needs to be?
Post by bohman731 on May 2, 2015 11:33:22 GMT -6
Bah it posted it upside down. So so keep that in mind.
Post by bohman731 on May 2, 2015 11:32:19 GMT -6
Alright so I got it apart and I can't seem to get the gear off. Do I need a puller? Or is there a way I can work it off without one? ![](http://s7.postimg.org/ctsc362pj/image.jpg)
Post by bohman731 on May 1, 2015 17:30:52 GMT -6
I haven't touched the scooter yet besides taking the cover off to inspect this
Post by bohman731 on May 1, 2015 16:09:21 GMT -6
If the gear on the crank ends up needing replaced, can I replace it by just removing the variator and getting to it that way?
Post by bohman731 on May 1, 2015 14:22:06 GMT -6
Hey guys. I just bought a 150cc gy6 Chinese scooter last night and I'm trying to get an issue sorted out. I had one of these a few years ago but sold it and I'm trying to refresh my memory on everything. On the kickstarter gears, the most forward gear seems to be not lined up with the gear just behind it. Before I tear into everything do you think it can just be adjusted inward to lineup or should I be worried about a different issue? Picture below kind of shows the problem. ![](http://s27.postimg.org/ekqkjldan/image.jpg)
Wiring Help
by: bohman731 - Jun 23, 2011 23:09:26 GMT -6
Post by bohman731 on Jun 23, 2011 23:09:26 GMT -6
hahaha yeah I made sure it was off. ![:)](//storage.proboards.com/3059616/images/ELWck45kIaBpPYtpvDIj.gif) I will see what happens after I install this new wiring harness then go from there.
Wiring Help
by: bohman731 - Jun 23, 2011 18:40:37 GMT -6
Post by bohman731 on Jun 23, 2011 18:40:37 GMT -6
the stator came with a new one of those tho
Wiring Help
by: bohman731 - Jun 23, 2011 17:16:18 GMT -6
Post by bohman731 on Jun 23, 2011 17:16:18 GMT -6
So here is the deal. I have not been able to get spark and I am about to light the thing on fire and be done with it.
I have bought a new stator, cdi, coil/wire and a plug. They all check out but I still dont have spark. The wiring harness looked fiddled with so I ordered a new one and should be here today or tomorrow. Everything is pretty self explanatory as far as how it all goes back in except a couple things. What color wires on the harness match up to the stator wires. Also what color wires from the harness go to the coil.
And how can I disable the alarm plug. I had it looped correctly on my old harness but when taking the harness off the wire came out and I cant find the diagram that I used to loop the plug.
I have a 2006 150cc gy6 Sunl
Thanks for the help
Post by bohman731 on Jun 2, 2011 21:21:41 GMT -6
This particular setup doesnt look like it would be too effective. I know turbos can work on scooters but I am not sure about this one. When the scooter came down to an idle it looked as if the turbo came to a stop. So either the turbo was not getting enough lubrication and the bearings were going out OR the scooter just can't put out enough exhaust to spin it fast enough. I doubt even the BOV (blow off valve) gets enough pressure to open up.
Post by bohman731 on May 31, 2011 22:22:23 GMT -6
I'll be ordering one of these guys now. Thanks for the help!!!!
Post by bohman731 on May 31, 2011 15:41:21 GMT -6
sorry I didnt specify what scooter I had. Dont know if it makes a difference for the tool. but its a 150cc will this one still work?
Post by bohman731 on May 31, 2011 15:06:07 GMT -6
Hey people. So I need to replace my stator but I can not for the life of me remove the flywheel. I tried a puller then I tried using heat and it just wont budge! I am getting frustrated and am not sure what to do besides take it to a shop.
Any suggestions?
Thanks
Post by bohman731 on May 11, 2011 17:01:49 GMT -6
I dont have a car fuel filter I have a gravity fed *designed* one
