Post by felliott on Oct 9, 2012 16:05:12 GMT -6
Take a flashlight and look in the gas tank. Does it look rusty, gooey or water in the tank? If it does fix that problem before cleaning the carburetor.
Post by felliott on Oct 7, 2012 16:30:20 GMT -6
If the battery is low on charge the wires will be warm. Make sure all grounds are clean and tight as mention above.
Post by felliott on Oct 3, 2012 16:35:41 GMT -6
Let us know what you find
Post by felliott on Oct 2, 2012 14:48:52 GMT -6
You should fix the play as soon as you can, may turn into a major safety issue and you do not want that.
Post by felliott on Oct 2, 2012 14:43:57 GMT -6
All shims that i have seen go on the right side. Just make sure the variator and clutch line up so the belt will run without binding.
Post by felliott on Oct 1, 2012 15:01:42 GMT -6
When you do remove the right side bearing sometimes there is a shim that must be put back on before the bearing is installed. Some cranks have a shim some do not. It is used to set crankshaft to case end play.
Post by felliott on Oct 1, 2012 14:32:59 GMT -6
The sproket on the right side is for the oil pump. Just press it off and put it back on. no alignment needed. The left side is for timing chain and needs to be put back in the same place as removed. I mark the top tooth clooses to the crank pin. Now mark the crank pin with a mark that lines up with the said tooth. I use a engraver pencil. When you reinstall just line up your marks. You will be good to go.
Post by felliott on Sept 30, 2012 15:12:26 GMT -6
I use a hair dryer to dry all wire connections. To get to ignition switch you will most likely have to remove a front panel.
Post by felliott on Sept 30, 2012 15:07:18 GMT -6
Post by felliott on Sept 29, 2012 17:03:58 GMT -6
Yes it will work well for both fuel and vacuum. It is also long lasting.
Post by felliott on Sept 25, 2012 16:43:40 GMT -6
We use 15w40 in all of our scooters.
Weak spark
by: felliott - Sept 19, 2012 16:25:41 GMT -6
Post by felliott on Sept 19, 2012 16:25:41 GMT -6
If you hear it in the area of the camshaft when you turn the engine over a small hiss is normal
Post by felliott on Aug 25, 2012 15:05:30 GMT -6
Could be drive belt causing it also.
Post by felliott on Jun 15, 2012 17:45:53 GMT -6
Not worry about it.
Post by felliott on Jun 8, 2012 17:37:11 GMT -6
15w-40 oil works great. It is used in trucks and you can find it most everywhere.
