Post by daddymark66 on Feb 27, 2018 23:05:37 GMT -6
I have one and love it.
Post by daddymark66 on Feb 27, 2018 23:02:33 GMT -6
Well thanks for the suggestions but I can’t seem to find it on any part diagram.
Post by daddymark66 on Feb 22, 2018 7:05:27 GMT -6
It does but it’s part of the fuel system.
Post by daddymark66 on Feb 19, 2018 10:43:06 GMT -6
Thanks guys. I’m still researching it. The hoses are on the bottom.
Post by daddymark66 on Feb 18, 2018 10:54:11 GMT -6
Post by daddymark66 on Feb 17, 2018 23:39:59 GMT -6
This little plastic canister is part of the fuel delivery system but I don’t see any purpose for it. Gas flows through it when the engine is running but there is no filter or anything under the cap.
Post by daddymark66 on Feb 17, 2018 23:32:34 GMT -6
Finally got to the valve adjustment on the Super this afternoon. Set both to 5 and it sounds so much better. I had to readjust the idle speed afterward because it was up around 2000 after the adjustment. The hard starting issue is gone too! Score.
Post by daddymark66 on Feb 17, 2018 23:25:46 GMT -6
I retired early about 2 years ago and have become addicted to scooters! I currently have 6 in my garage! One was bought new but all the others were bought in various stages of used condition. I have learned so much from the posts on this board and of course from YouTube and trial and error.
Post by daddymark66 on Feb 17, 2018 15:05:03 GMT -6
8900
Post by daddymark66 on Feb 16, 2018 10:32:26 GMT -6
This morning I took out the oil pump and cleaned it. Put it back in and checked the flow but nothing is coming out. Could this be the white smoke culprit? Not enough oil?
Post by daddymark66 on Feb 16, 2018 9:28:16 GMT -6
White smoke.
Post by daddymark66 on Feb 15, 2018 20:19:18 GMT -6
I have a 2008 Genuine Buddy that I’ve been working on for some time. It starts right up on the first push on the button but it never seems to get out of choke mode. It revs pretty fast so you have to pull back on the grips to keep it stationary. I’ve tried to adjust the idle and air mixture to no avail. Once it warms up, the idle returns to normal but after applying throttle, returning to idle takes about two to three second which makes stopping and staying stopped a challenge. It’s is also producing an irritating cloud of smoke from the muffler. Im trying to order a new carb but they are super hard to find. I was also thinking about replacing the reed valve and taking apart the oil pump and cleaning or replacing it. Am I on the right track? Thanks in advance.
Post by daddymark66 on Feb 6, 2018 22:09:54 GMT -6
Another issue these seem to have is a faulty charcoal canister that is preventing the gas tank from venting properly. After it runs for a bit, take off the gas cap. If you hear a rush of air your tank is not venting properly. You can either drill a small hole in the gas cap or remove the fuel venting system altogether. There is a thread about how to do that on this board somewhere and lots of YouTube videos
Post by daddymark66 on Feb 5, 2018 17:38:49 GMT -6
Mine was doing the same thing. You can either drill a small hole in the fuel cap or disconnect the whole vent canister system. Drilling the hole was easier. If you get a rush of air when you take off the gas cap that’s probably what’s wrong. I’m gonna look for a replacement canister too.
Post by daddymark66 on Feb 5, 2018 17:35:12 GMT -6
