Certified Clinician
Windshield
by: kountryguy - Oct 28, 2021 23:26:48 GMT -6
Post by kountryguy on Oct 28, 2021 23:26:48 GMT -6
I am looking for a windshield for a 2021 Kymco People S150. Anyone know where to buy one?
Certified Clinician
Post by kountryguy on Sept 20, 2019 10:23:02 GMT -6
I have a SSR Pacificia 150. Yesterday I pulled the exhaust off in order to pull the rear wheel. In doing so, I noticed there is a Y in the pipe where a small pipe goes off to a small box and a rubber tube goes off of that. It had become disconnected and I do not see where to reconnect it. I do not know what it is for. Can someone enlighten me what it is for and where to reconnect it?
Certified Clinician
Post by kountryguy on Aug 2, 2019 21:26:02 GMT -6
I have a SSR Pacifica 150 scooter with a windshield and a trunk. Can anyone recommend a cover and a place to get one? I cover it when transporting it behind my RV. Thanks for any suggestions.
Certified Clinician
Post by kountryguy on Sept 5, 2018 18:25:40 GMT -6
I have a SSR Pacifica 150 that will not start electrically. It started 3 times yesterday and them the fourth time, nothing. I kick started it and drove it home. I noticed that when I turn the ignition switch on, the digital clock goes off. When I turn off the ignition switch, the clock comes back on and resets to 12:00. I am thinking it may be a bad ignition switch. Any thoughts?
Certified Clinician
Won't Idle
by: kountryguy - Mar 24, 2017 20:54:45 GMT -6
Post by kountryguy on Mar 24, 2017 20:54:45 GMT -6
I did leave the cap off and made no difference. Can you refresh my memory what the valve settings are.
Certified Clinician
Won't Idle
by: kountryguy - Mar 24, 2017 18:16:00 GMT -6
Post by kountryguy on Mar 24, 2017 18:16:00 GMT -6
I have a SSR Pacifica 150. I was out riding for about an hour and came to a stop sign. The scooter stalled and would not start. I let it sit for 1/2 hour ,tried again, no start. Got friend to haul me home. Pulled the spark plug and it was dry. Someone suggested vapor lock. I removed the cap and it started. Ran it for a couple of minutes at speed, let off the throttle and it stalled and was reluctant to start again. I wondered about the fuel filter, but I would think that would affect it more at high speed. I tried turning up the idle and that did not seem to help. This scooter only has around 600 miles. Any ideas?
Certified Clinician
Post by kountryguy on Nov 28, 2016 20:02:03 GMT -6
What temp should the oven be set at?
Certified Clinician
Post by kountryguy on Nov 17, 2016 21:27:47 GMT -6
I have a new SSR Pacifica 150. I has chrome hear shields in the muffler. Has anyone found a way to prevent them from rusting?
Certified Clinician
Post by kountryguy on Sept 30, 2016 11:34:09 GMT -6
I had a Roketa MC-70-150. I sold it thinking I could find something similar to replace it with. I am not having much luck. Can anyone recommend a new scooter with 16" wheels and front and rear disc brakes? Any suggestions will be appreciated.
Certified Clinician
Gas in Oil
by: kountryguy - Aug 1, 2016 19:07:19 GMT -6
Post by kountryguy on Aug 1, 2016 19:07:19 GMT -6
I will chech all those things the first chance I get. Thanks, I will let you know.
Certified Clinician
Gas in Oil
by: kountryguy - Jul 31, 2016 15:47:20 GMT -6
Post by kountryguy on Jul 31, 2016 15:47:20 GMT -6
I have a Roketa MC-70-150. The last time I changed the oil it appeared to have gas mixed in. The scooter had been blown over in a wind storm and laid on its side for only about a minute, but I thought that maybe the float had stuck and allowed gas to flow into the crankcase. I changed the oil and have taken a couple of trips totaling about 100 miles. The scooter is running perfectly, but When I returned from the second ride, I noticed that the oil level is rising. Any thoughts on how I should proceed?
Certified Clinician
Post by kountryguy on Mar 20, 2016 17:00:38 GMT -6
Can someone refresh my feeble memory as to how much oil a GY6 motor should hold? Thanks.
Certified Clinician
Post by kountryguy on Oct 1, 2015 12:39:56 GMT -6
I have a Roketa MC-150-70. My headlight and taillight and brakelight have stopped working. Any suggestions on where to start looking? Thanks for any suggestions.
Certified Clinician
Post by kountryguy on Jun 14, 2015 18:23:34 GMT -6
I have a Roketa MC-70-150. It has a 110/80-16 rear tire. I am having a little trouble finding that size tire. Has anyone had success replacing that size with a 120/80-16. It looks like it would be less than a half inch wider than the original. What are your thoughts? Thanks.
Certified Clinician
Post by kountryguy on Sept 4, 2014 17:09:01 GMT -6
I agree. A link to these LED bulbs would be helpful.
