Post by philr54 on Aug 14, 2011 14:07:26 GMT -6
It doesn't fit on the engine, it is the engine (rightside crankcase).
Post by philr54 on Jun 4, 2011 16:00:57 GMT -6
And a RON rating 90 = 86.6 Pump Octane Number (US octane rating) Article
Post by philr54 on May 9, 2011 17:58:53 GMT -6
Post by philr54 on May 7, 2011 14:33:24 GMT -6
You might check out a BMS Zen King. 16" wheel with a disk brake on the swingarm
Post by philr54 on Mar 24, 2011 14:57:18 GMT -6
Post by philr54 on Nov 5, 2010 19:36:50 GMT -6
presently goes to plastic round component with a second hose coming off and going to a round shot glass size part that has end filed with holes that draw in outside air. Lose that - a constant source of irritation and vacuum leaks
other thing noticed is idle /fuel adg. screw doesn't seem to produce much of a chnge in RPM.
Mine came with a #32 pilot jet / #105 main and ran way too lean - had to back the AF screw out 4+ turns. Went to #38 pilot/112 main jet which worked considerable better
Post by philr54 on Oct 8, 2010 13:28:56 GMT -6
Yeah, it's running again. The Mikuni fuel pump quit on me and I killed the already weak starter trying to get it running. Original fuel pump, new starter, new battery - varoom. Just turned 10000 miles on it.
Post by philr54 on Oct 5, 2010 16:26:54 GMT -6
I was getting a surging on my 150cc scooter and I figured it must be either in the belt or rollers. Scoot had 1,800 miles on it when it started getting worse. I ordered a new belt from Scrappydogscooters and rollers. My scooter came with 17 or 18 gram rollers and I dropped it back to 15 grams. The belt was 835 and I went to a 842. The new belt and rollers cured the surging and my speed went up nearly 5 MPH. Today I took my GPS along for the ride to check the actually speed, 55.3 MPH, a new record for this scooter. Previously it would top out at 55 on the Chinometer now it's 59 on the Chinometer. This was on level ground and I was wearing a heavy coat, gloves and riding normally sitting up. I would imagine if I went into a full tuck I might be able to squeeze 60 MPH out of her. I weigh 220 lbs. so I guess that's not too bad for a 150cc scooter. Gary Told ya you'd like it. That 835 belt and 17g rollers definitely hold you back. Wait till it gets broke in good.
Post by philr54 on Jul 19, 2010 23:09:29 GMT -6
828-22.5-30 is standard for the 244cc with a 10" wheel. With a 13" wheel I guess we have a long case 244. The belt on my M3 is unmarked. Using the nominal and actual dimensions of a gy6 835 belt and the OD of the M3 belt, I come out with 918-22.5-30 as the belt size, there is a 906 belt that might also work. I also found there are 2 possible variators for the 244cc, 128mm and 138mm. Keeping in mind my limited experience with scooters, the first thing that comes to my mind is a clutch bearing. It will work fine on the center stand but under a load you get serious belt slippage and low speeds - had that experience with my Carino. I don't know if that could cause the belt slap you spoke of - I haven't had that problem.
