Certified Clinician
Post by alansd on Oct 21, 2014 9:49:50 GMT -6
so thats why I could not find my adjustment screw..
I put a new plug and gas filter on my scoot, then adjusted the idle..it runs a whole lot better than it did..Might have to get at that other screw now to tweak it too
Certified Clinician
Post by alansd on Oct 3, 2014 9:40:55 GMT -6
Just wondering if anyone has 20,000 or 30,000 miles or more?
Mine only has 2600, so it has a ling way to go
Certified Clinician
Post by alansd on Sept 10, 2014 7:21:27 GMT -6
these things are a lot more dependable than the uneducated give them credit for. Mine now has 2500miles so its got a long way to go.
Certified Clinician
Post by alansd on Sept 4, 2014 13:34:26 GMT -6
sounds exactly like it thanks Alley
Certified Clinician
Post by alansd on Sept 3, 2014 15:54:00 GMT -6
My scooter runs well most if the time, but if I crank the gas a bit too much it feels like its holding back. Almost stalled a few times. Any ideas?
Certified Clinician
Post by alansd on Jun 6, 2014 20:04:36 GMT -6
thanks bro, kinda what I thought guess I didn't push the needle down enough.
Certified Clinician
Post by alansd on Jun 6, 2014 16:23:47 GMT -6
Need help with putting the last pieces back on the carb...how does this little white plastic thingie go in? With the hole side down? The spring on top?
Certified Clinician
Post by alansd on Jun 6, 2014 8:21:48 GMT -6
thanks. I prefer Irish whiskey but I get the point. Those tabs are a b**ch. I got a crack in the side I am going to fill and sand, better to have the body parts off to do it.
Certified Clinician
Post by alansd on Jun 5, 2014 15:30:36 GMT -6
I am trying to take off the main body section under the seat and all. I am not sure what clips on and what screws on. I removed the screws I found also inside the storage area, took off the luggage rack, now what?
Certified Clinician
Post by alansd on May 20, 2014 10:40:10 GMT -6
I don't ever ride on major roads or highways, just two lanes around the town. Traffic is usually 35-45 mph range
Certified Clinician
Post by alansd on May 20, 2014 10:38:55 GMT -6
49 cc is what it has. The scooter does pretty well, but inclines are noticeably slower
Certified Clinician
Post by alansd on May 16, 2014 16:22:41 GMT -6
My Scooter runs great and does pretty well cruising, but of course slows down on any hill. If I update the variators weights to sliders, can I expect a bit more power for the hills? If so what weight should I look for? Any other tips are appreciated.
Certified Clinician
Post by alansd on Mar 13, 2014 9:05:55 GMT -6
meanwhile back to oil-- I changed my oil ( first time) yesterday and the gear lube. Used 10-40 Valvoline Motorcycle oil and Valvoline Gear oil . Was so easy I was surprised. I bought it with 1400 miles on it it now has 2000. The oil screen was perfectly clean but I spray cleaned it anyway.
Been running some SeaFoam in the gas every once in awhile and the little scoot runs great.
Certified Clinician
Post by alansd on Mar 5, 2014 11:33:29 GMT -6
I want a Ruckus style scoot... Oh yeah I invented the internet before Al Gore did what about this one...? Ruckus (sort of)
Certified Clinician
Post by alansd on Mar 5, 2014 11:29:14 GMT -6
My Starbucks would pop right out of that drink holder. Or leak. Haven't quite solved that issue yet
