Doc's Anything Goes
Post by adamhoyer on Oct 20, 2015 15:00:23 GMT -6
Doc's Anything Goes
Post by adamhoyer on Oct 20, 2015 15:00:09 GMT -6
Doc's Anything Goes
Post by adamhoyer on Oct 18, 2015 17:33:40 GMT -6
It's still doing the same thing, made sure it was top TDC on the compression stroke with the cam lined up, made sure the 0.005mm feeler gauge would not fit in afterwards and it still sounds like crap but it has great compression.
Doc's Anything Goes
Post by adamhoyer on Oct 16, 2015 22:06:57 GMT -6
Got it alley, tomorrow I will try again.
Doc's Anything Goes
Post by adamhoyer on Oct 16, 2015 20:52:28 GMT -6
yup I always have the cam sprocket lined up too I check before .
Doc's Anything Goes
Post by adamhoyer on Oct 16, 2015 13:51:43 GMT -6
I guess I will adjust the valves again and see what happens ![:(](//storage.proboards.com/3059616/images/9vHkitM8Se1RGkD72ccA.gif) LOL I always let the engine cool off and then turn the engine by hand till the intake valve closes and then line up the flywheel mark just behind the f t/ / /
Doc's Anything Goes
Post by adamhoyer on Oct 16, 2015 13:02:03 GMT -6
Sorry been away for a while working and upgraded to a motorcycle so I've been a little preoccupied. I have checked the scooter for compression, spark, fuel, valves and just changed the variator/weights and belt. I uploaded a really good sound quality video to show you the sound of the scooter. the pictures and video
Doc's Anything Goes
Post by adamhoyer on Jul 7, 2015 15:10:24 GMT -6
Doc's Anything Goes
Post by adamhoyer on Jul 2, 2015 12:27:11 GMT -6
And when I reverse my blinker clip on thingys the right blinker works but the left dosent, and I have to blink to the left to get the right on working when reversed.
Doc's Anything Goes
Post by adamhoyer on Jul 2, 2015 12:26:05 GMT -6
My front right blinker is not working but my all my other blinkers are, I have tried to change the light. I found the wires on the front headlight harness that connects to the blinkers have been wrapped with electrical tape. The green wires are all in a bundle exposed just a little bit about this much --- and wrapped around each other and there was a brown wire that was exposed that looked like it was soldered little bit. any ideas? i got my fluke meter ready.
Doc's Anything Goes
Post by adamhoyer on May 16, 2015 14:01:54 GMT -6
The new scoot is okay, I get a big vibration from the front at 35mph and then it goes away after getting to 40 and I can figure out how to get the damn plastic off on the back for the side to come off without breaking it.
Doc's Anything Goes
Post by adamhoyer on May 1, 2015 21:38:49 GMT -6
Just bought a ssr interceptor 149.6cc, breaking it in slow i'll let you know how it turns out.
Doc's Anything Goes
Post by adamhoyer on Apr 30, 2015 11:58:43 GMT -6
Doc's Anything Goes
Post by adamhoyer on Apr 18, 2015 10:58:38 GMT -6
I told them 157qmj sonic deluxe 2013 model they had all the specs they should have the rim size for that model as they are the dealer.
Doc's Anything Goes
Post by adamhoyer on Apr 17, 2015 23:09:31 GMT -6
Just bought an engine from ssrmotorsports and it's the wrong one, because my rim does not fit because the engine is for a 10" rim the bn157qmj . I guess we will see if they will pay for return shipping and or if they will send me another engine.
