Post by cfreeland on Aug 17, 2014 19:55:30 GMT -6
Ok guys I've screwed up.
I stripped my spark plug socket so I went to my local auto zone the guy told me just to get a tap and dye rethreading tool 10mm x 1in. So I did and used it but now my spark plug wont even catch when I'm trying to tighten it in (Which is way worse than before when it was at least catching and then missing threads). Any advice?
Post by Alleyoop on Aug 17, 2014 20:18:59 GMT -6
Post by richardv on Aug 17, 2014 20:41:59 GMT -6
I have used on of those on a motorcycle and found I needed to use a spark plug in a lower heat range. The repair insulated the plug and made it run hotter. That may not be the situation in your case but, check the plug for signs of running hot. It's similar to running the engine lean.
Post by cfreeland on Aug 17, 2014 20:43:30 GMT -6
I'm thinking about just getting a new head any places that are reasonable
Post by Alleyoop on Aug 17, 2014 20:49:08 GMT -6
Ebay are the cheapest you will find.
Post by adamhoyer on Aug 17, 2014 21:36:07 GMT -6
Post by cfreeland on Aug 18, 2014 9:03:30 GMT -6
oh no I have a 50cc p139qmb
Post by steelblade on Aug 18, 2014 10:50:00 GMT -6
I've used a rethread kit on my old car and they don't seem to last well. The new head may be your best bet.
Post by jct842 on Aug 18, 2014 13:20:11 GMT -6
I have seen quite a few people just get a tap for the next size bigger spark plug, tap it using grease just like the video and be done with it. Your screwed if you already are using a big thread plug though.
Post by cfreeland on Aug 18, 2014 17:18:16 GMT -6
Where can i buy a head for 50cc p139qmb im just seeing ones for 139qmb
Post by gatekeeper on Aug 18, 2014 17:31:21 GMT -6
Sameo sameo. Just find out if your valve length is 64mm or 69mm long. Rocker arm must match.
