Certified Clinician
Post by dozer187 on Mar 11, 2017 23:16:47 GMT -6
Does anyone know what size screw the battery door has on it on a powermax 150cc, its the single screw 2 tab door, som asshole stole my battery and the screw is gone so i wana see if i can get a locking bolt for it
Certified Clinician
Idle issues
by: dozer187 - Mar 4, 2017 16:54:52 GMT -6
via mobile
Post by dozer187 on Mar 4, 2017 16:54:52 GMT -6
I just blocked off mine completely. Really helped me. Do one change and check results. You blocked off the enricher? How?
Certified Clinician
Idle issues
by: dozer187 - Mar 3, 2017 13:41:36 GMT -6
via mobile
Post by dozer187 on Mar 3, 2017 13:41:36 GMT -6
Already checked the idle adjust screw, ill do a valve adjust probably tomorrow, gota open yhe airbox to see which filter type i have. Is there an easy way to check if the enricher is working properly?
Certified Clinician
Idle issues
by: dozer187 - Mar 3, 2017 11:05:57 GMT -6
via mobile
Post by dozer187 on Mar 3, 2017 11:05:57 GMT -6
So ive got a 150cc powermax stock aside from exhaust replacement cuz original fell apart and a tuneable oem carb. Lately my idle has been high when riding, i checked all vacuum lines and couldnt find a leak, all gaskets are good as well. Im thinking it could be valves needing adjustment, im also still using original airfilter and im at 3500miles so im sure its filthy, is there anything else im overlooking that could be causing it?
Certified Clinician
Post by dozer187 on Nov 6, 2016 18:21:57 GMT -6
U running led or stock turn signals
Certified Clinician
Post by dozer187 on Nov 6, 2016 15:03:10 GMT -6
Are all the bulbs good?,,,even so there's not enough load to make the flasher cycle,,,I use digitalis myself,,couple bucks more but they cycle whatever the load is where did u get the digitalis
Certified Clinician
Post by dozer187 on Nov 5, 2016 12:56:58 GMT -6
Bulbs are all fine, just stayin solid with this relay,
Certified Clinician
Post by dozer187 on Nov 4, 2016 21:19:55 GMT -6
Certified Clinician
Post by dozer187 on Nov 4, 2016 18:09:32 GMT -6
Ok so i hooked up the universal, and the blinkers just stay solid on
Certified Clinician
Post by dozer187 on Nov 2, 2016 19:40:43 GMT -6
I have had good luck with the universal if that was the Question. With the stock turn signals?
Certified Clinician
Post by dozer187 on Nov 2, 2016 18:22:15 GMT -6
Its getting power, 12v with signal switch in either position, showed like 14 in neutral (off) position, checked every connection on the harness all good, thats y i asked about the part. To see if a universal would work
Certified Clinician
Post by dozer187 on Nov 2, 2016 11:01:28 GMT -6
Will a universal work for stock turn signals or do i need oem part
Certified Clinician
Post by dozer187 on Nov 2, 2016 8:00:28 GMT -6
So i have a powermax 150 and my turn signals stopped working this morning , still have tail and brake light and headlight and running light, horn works too. Bike starts with starter no problem
Certified Clinician
Post by dozer187 on Aug 30, 2016 14:40:41 GMT -6
Ive already got the new exhaust, im trying to figure out what jet to use cuz the stock isnt marked, exhaust is the only mod i have everything else is stock
Certified Clinician
Post by dozer187 on Aug 25, 2016 18:18:38 GMT -6
Ok so ivhad the exhaust welded, but the brackets are far to cheap so they broke again, my question at this point is if i get an aftermarket exhaust and run stock intake am i still gona need to up jet
