Scooter Doc
![*](//storage.proboards.com/forum/images/stars/star_blue.png) ![*](//storage.proboards.com/forum/images/stars/star_blue.png) ![*](//storage.proboards.com/forum/images/stars/star_blue.png) ![*](//storage.proboards.com/forum/images/stars/star_blue.png)
Post by seanstr on Aug 24, 2018 5:22:30 GMT -6
I have lost my exhaust studs. I need to know the size to order more. Does anyone know the size?
Scooter Doc
Post by seanstr on Jan 27, 2018 6:09:56 GMT -6
For me it was the auto choke. Mine wouldn't close. I am not getting enough voltage to get it function right. So I blocked it off. Even now when I come to an abrupt stop and then try to take off immediately it tries to stall. It can die. I think there's full still getting in the auto choke chamber. Just enough to cause this.
But unplug remove the auto choke and see if does what it is supposed to, open up (pull up into the auto choke) right away then close after some time (re-extend back out)
Do one change and check results.
Scooter Doc
Post by seanstr on Sept 13, 2017 10:22:50 GMT -6
So You set the Timing mark on T then you set the top dead center by removing the valve top and then set the top dead center to match, then you tightened it all down then you adjusted the valves, right.
Scooter Doc
Post by seanstr on Aug 23, 2017 4:49:48 GMT -6
Should think about making City Museum a rally point. Plenty of street parking and seems an apt destination for a pile of DIT wrenchers. I like it. I will try to get others get involved, see if they would enjoy that.
Scooter Doc
Post by seanstr on Aug 23, 2017 4:47:38 GMT -6
So, since I got the Lance doing well I started on my Honda sh150i. It was getting 80 mpg and could get to 65 mph. I only adjusted the rollers weights. Went up 5 grams. From 13 grams rollers to 18 grams rollers. Now I can get up to 70 mph and can get 96 mpg. Yay
Scooter Doc
Post by seanstr on Aug 23, 2017 4:41:53 GMT -6
125 give or take a mpg or two,, four stroke stella 150,, fourspeed manual trans,,, 75-80 degree day,,,, Wow! Not getting that much.
Scooter Doc
Post by seanstr on Aug 23, 2017 4:39:59 GMT -6
Or you can...Put in gas, record number of gallons and miles traveled, then ride....put in gas, record number of gallons and miles traveled, then ride....etc. Won't effect the smiles per mile at all, and just might let you know a bit earlier, that your scoot isn't feeling quite up to par. That too.
Scooter Doc
Post by seanstr on Aug 14, 2017 8:34:53 GMT -6
How fast can you get up to, no wind pushing or pulling, flat road?
Scooter Doc
Post by seanstr on Jul 11, 2017 15:49:48 GMT -6
I had this problem, figuring out the right jet for the main jet. Try like rks stated, go up then slowly go down in size. Too lean can do damage, too rich won't. Make sure the valves are adjusted correctly, air filter clean spark plug wire is good, etc, before you attempt jet changes. Fuel filter too.
There is computation you can use. the inner diameter of the carb going to the engine times a constant = main jet size, where the constant is a bit less than 4 to 5. It gave me the courage to go down far enough to find the correct jet size.
Scooter Doc
Post by seanstr on Jul 11, 2017 15:33:29 GMT -6
My 300cc trike 60 mpg but I'm a little heavy 235 and so is my wrist crusting speed 45 to 55 most of time. I weight 250lbs or so and I have a 125cc. It's directly related to the cc's. How fast can you get the Trike up to? I can do 55mph an a good hot day, no wind pushing at me. Do one change and check results.
Scooter Doc
Post by seanstr on Jul 10, 2017 13:42:05 GMT -6
You might just pull the cvt cover, and see what is stamped on the original belt. That way you'll be sure you're ordering the right size....not what someone else believes to be the right size. Gates Premium, or Bando.....search and pick a vender. Do one change and check results. Completely correct, best way to get the right one.
Scooter Doc
Post by seanstr on Jul 7, 2017 13:53:13 GMT -6
I am currently getting 90mpg, 125 cc carbureted, as you know, and I can get up to 56 sometimes, and 52 is more normal depending on how hot it is. Hotter is better for my carb adjustments.
Scooter Doc
Post by seanstr on Jul 7, 2017 12:59:19 GMT -6
I'm down to ride come April when it warms up.I reside in STL city I got my scooters running well enough. How fast can you go top end? I'm in Granite City. Do one change and check results.
Scooter Doc
Post by seanstr on Jul 5, 2017 7:14:31 GMT -6
Do you have a scale? Weight the ones you have in grams, then measure the rollers in metric. This will give a good idea of where you are starting at. Then decide what you want as results.
Heavier higher top end save a little bit more gas. Lighter, takes off faster uses a bit more gas. IMO
Ever gram you go up or down changes the RPM's by 500 RPM's Sliders are nice if you can keep them in the variator not getting shifted as mine kept doing.
You can go one gram up from the weights you are on and have little affect on total performance but might have a slightly higher top end.
Also you can get a tuning kit from Prima on eBAY. They are very useful.
All this is dependent on the carb being tuned correctly.
Have fun
Scooter Doc
Post by seanstr on Jul 5, 2017 6:59:33 GMT -6
You can order diaphragms but they don't always fit. I had to order 3 different ones. 2 worked 2, the other didn't. I also replaced whole carb thinking it was something else. I had 2 issues. My choke stopped working, even when newly replaced and the hole in the diaphragm. I ended up blocking off the choke. runs great was only getting 60 to 70 mpg. After the change I am getting 92 to 94 mpg. Hugh difference. Had to decrease my main jet also.
