Senior Clinician
East Tawas MI
Post by Tawas on Mar 6, 2017 7:58:39 GMT -6
I was think the valves are coming down hard because just installed could that be there smashing down to fast or hard because of new cam higher lobes will this sop also think my oil is to thin 10w30
Senior Clinician
East Tawas MI
Post by Tawas on Mar 6, 2017 7:32:47 GMT -6
Just installed the A9 cam and bigger valve head and have a slight ticking .have had my BB kit installed for awhile and just wanted a little more top end I set the valves 3 times and know thats not the noise not a clattering just a ticking thinking my be valves as just installed and know there opening higher due bigger cam is this normal and will it stop over time checked exhaust and not leaking is this normal .new plug also..
Senior Clinician
East Tawas MI
Post by Tawas on May 25, 2016 7:18:07 GMT -6
ok thank for the help my main jet is 85 I believe I shouldn't have to change that or do I because all I added to my 80cc bbk is the head 64mm valves and the A9 cam ran really good before these 2 add ons and as of sliders what is recommended as I will be cleaning that area too only had about 500 miles on my 80cc kit with stock head so changing just head 64mm and A9 cam thinking everything else should be ok correct
Senior Clinician
East Tawas MI
Post by Tawas on May 24, 2016 7:02:52 GMT -6
ok other than that is there any other info you can tel me to check and will this be a big improvement that I AM expecting ...
Senior Clinician
East Tawas MI
Post by Tawas on May 23, 2016 16:46:32 GMT -6
I have a 2012 VIP TAO TAO with a BB KIT installed bought the bigger 64mm valve head and wanted to ask after buying the rocker arm update for valves are the gap still .004 on both and is there any other adjustments I need to look at before installing this into the scoot the head I was using was stock so I bought the correct head and this A9 cam should anything else be looked at while this kit is being installed so I know while engine is out of scoot and what jets on carb should I be using just to confirm my upgrades thanks in advance ..
Senior Clinician
East Tawas MI
Post by Tawas on Apr 13, 2016 6:35:49 GMT -6
I have a 150cc and having issues idling I cleaned carb and do know about the klien very much I have the common CV carbs but not this klien one.. I know the enricher isnt working but think the side vacuum has issues also.. I would like to switch the carb to the one other more common kind that are on most of the scooters and get rid of this klien as I have many of in stock and have lots of experience with the easier common cv is this possible and if I can what are the jet sizes for a stock 150cc as no mods are on here just for not want to switch same 24mm size I believe but what jets do I need ..I just don't like the klien there not as simple as the regular gy6 cv carbs ..so can anyone tell me the size carb and jets to buy for stock 150cc go Karts gy6 ..thank you .
Senior Clinician
East Tawas MI
Post by Tawas on Mar 15, 2016 8:53:49 GMT -6
ok thank you for the help
Senior Clinician
East Tawas MI
Post by Tawas on Mar 14, 2016 15:04:18 GMT -6
After reading some of my older posts looks like my BB kit is the 80cc when I bought it it came with the kit but now I see on ebay they dont sell BB kit with the head on most since I stupidly stripped out my spark plug hole can I just put my stock head back on it looks the same as the one I have on now will this help me alot of hassle of ordering just the head since it just sitting in my parts shelf ..I did reading and sounds like I will be ok doing that just want to make sure before I start the repair ..thanks for helping as I have not work on mine in a while ..
Senior Clinician
East Tawas MI
Post by Tawas on Mar 14, 2016 12:28:04 GMT -6
thank you for helping me I really appreciate it ..means alot to me thanks again
Senior Clinician
East Tawas MI
Post by Tawas on Mar 14, 2016 11:42:44 GMT -6
Is the 14x1.5 correct he said he thinks it is can anyone tell me 100 percent that it is 14x1.5 thanks
Senior Clinician
East Tawas MI
Post by Tawas on Mar 14, 2016 9:44:43 GMT -6
I have my spark thread has stripped out can anyone tell me what thread it is as I want to get a kit to fix this being I have done this many times with other types with great results I just want to make sure I get the thread type correct 2012 VIP with BB kit 72cc but is same as stock 50cc thanks in advance ..
Senior Clinician
East Tawas MI
Post by Tawas on Mar 12, 2016 7:20:57 GMT -6
ok thank I will use the 32 because I know what it is by marked and the other is not marked and cant tell what it even is thanks again
Senior Clinician
East Tawas MI
Post by Tawas on Mar 11, 2016 15:12:02 GMT -6
Working on the scoot and want to ask if the stock 50cc idle jet the one I going to try is the #32 and I compared it to the stock ones I have the bottom holes are smaller dia than the #32 which is marked 32 and the stock one has no marks and holes look bigger clearly is that correct stock bigger looking holes is what I have been running
Senior Clinician
East Tawas MI
Post by Tawas on Mar 10, 2016 14:23:27 GMT -6
Going today to fix the issue above and had few more questions I now have the Blue CDI pictured in other posts but did some reading about them not being so good should I keep that box if working or switch to stock box I do have a orange castol CDI and I have that after market boost bottle from cab mount boot should I remove that I dont know if that is a helping or just a item that does nothing..just to verify on my 70 BB KIT listed above my valve gap should be at .004 not .002 cold set like stock 50cc says .002 ..just wanted a tip on if I should change any of that or just use it ..thanks again for helping me your great people on this site it really helps me ALOT ..
Senior Clinician
East Tawas MI
Post by Tawas on Mar 5, 2016 18:39:26 GMT -6
ok sounds good I will do exactly that thank you for the help
