Post by sctrdawg on Mar 1, 2011 16:22:16 GMT -6
cool! thanx guys
Post by sctrdawg on Mar 1, 2011 10:19:09 GMT -6
Ok , I know what the "t" is on the fly wheel . What does the "f" stand for?
big bore
by: sctrdawg - Feb 10, 2011 11:55:18 GMT -6
Post by sctrdawg on Feb 10, 2011 11:55:18 GMT -6
will a 150 gy6 cylinder and piston work on a 50cc gy6 case?
Post by sctrdawg on Dec 15, 2010 23:18:06 GMT -6
my throttle cablekeeps getting stuck and it seems to be due to the cold at night!! i replaced it today and it stuck again tonight !! had to ride twelve miles with it stuck wide open!! thought maybe moisture in the cable froze it stuck, but the one i put on today has bee inside out of the elements!! HELP!!!!!!
Post by sctrdawg on Nov 24, 2010 11:03:58 GMT -6
Thanx!!
Post by sctrdawg on Nov 22, 2010 11:40:47 GMT -6
my key broke off in switch . removed it and had to leave it switched on for the bike to run. now i need to install a toggle switch to cut it all off so my batt. doesnt run down over night . using the engine run / stop switch on handle bar to cut on and off but power still goes to turn sig., etc. help !! where do i interrupt the circuit to kill all power to everything with my toggle switch! my scoot is an 09 motofino 50 qt-10d
thoomp!
by: sctrdawg - Oct 24, 2010 21:58:04 GMT -6
Post by sctrdawg on Oct 24, 2010 21:58:04 GMT -6
will try thanks!~!
Post by sctrdawg on Oct 24, 2010 21:56:35 GMT -6
K bad choice of words they dim a lil when using turn sigs. when i'm riding and hit either brake they dang near cut off!
thoomp!
by: sctrdawg - Oct 23, 2010 22:58:47 GMT -6
Post by sctrdawg on Oct 23, 2010 22:58:47 GMT -6
when i take off , after a couple seconds my scoot makes a thoomp! or foomp!! sound it seems to come from the air inlet area say the air cleaner (aftermarket) or the boot between the aircleaner and carb ! or maybe even the carb itself! Help!!
Post by sctrdawg on Oct 23, 2010 22:51:44 GMT -6
why do my headlights dim when i hit the brakes? why do my headlights flash when i use my turn signals?
Post by sctrdawg on Sept 3, 2010 6:41:29 GMT -6
Got figured out ! they sent me a crank for a Znen scooter which uses 22 teeth on the oil pump sprocket. sent it back and exchanged for the crank with the 16 tooth sprocket!!!RIDIN' AGAIN SOON!!
Post by sctrdawg on Sept 2, 2010 7:23:41 GMT -6
they don't have the number on their site!
Post by sctrdawg on Sept 1, 2010 18:14:24 GMT -6
Post by sctrdawg on Sept 1, 2010 18:11:27 GMT -6
Cranks and sprockets are the same ! Why in the heck won't they mesh??!!
Post by sctrdawg on Aug 28, 2010 21:22:40 GMT -6
Bought it from scrappy dog scooter parts! i gave it up for the evening ill count them tomorrow!
