Certified Clinician
Post by looker on Nov 22, 2012 13:37:00 GMT -6
That is strange John.! The Champions I used to use were the 'Double Copper' ones, from memory, a copper centre electrode and a copper core side electrode. No idea if it was a gimmic, they were a little dearer than regular ones, but they always worked well for me. Used them for years in all the various cars I had. Anyone I knew that had ignition problems back them tended to have NGK's installed! Funny how things are different from country to country, maybe they were different plugs?
Certified Clinician
Post by looker on Nov 22, 2012 3:31:04 GMT -6
Terrilee, I know, it's amazing the difference just a plug can make. I could clearly feel it on the scoot, x that by 4 in the cage and the difference is unreal. Funny thing is, I used to hate NGK plugs with a passion some 20 years ago after a set I bought for the cage I had back then lasted only 200 miles. They were the correct plugs for the application too. I'm a firm believer in having a strong ignition system, I used Champion Double Copper for many years, then Bosch Super Four, but these NGK Iridium are something else. Long may they be around! Thanks guys, and gal
Certified Clinician
Post by looker on Nov 20, 2012 4:25:55 GMT -6
Have been running my scoot with NGK iridium's since the get go, they make a great difference with a smoother idle and pickup. So, when it came to servicing the cage recently I decided to give them a go on the old girl. Holy cr*p, what a difference, you really can notice it on 4 cylinders (yeah, only 4, I'm in the U.K.). It actually feels like it's putting out more horses now! Can only imagine what a full set would do in a V8 across the pond
Certified Clinician
Post by looker on Nov 20, 2012 4:18:52 GMT -6
I always had this problem on my scoot, changed carb, intake manifold, vacuum lines, even the exhaust manifold gasket. Nothing stopped the popping/farting 'til I removed the P.A.I.R system. Now it's gone, so has the popping.
Certified Clinician
Post by looker on May 12, 2012 14:27:23 GMT -6
Hi Rob, good to see a fellow countryman here Couple of things if I may, CBT lasts 2 years, not 3. Yearly MOT only applies after the vehicle is 3 years old. Bashan, we pay national insurance directly out of our pay packs to fund the 'universal health care' system, as we know it the NHS (national health service) Duty/tax from fuel does not fund the NHS. The government take about 60% in tax/duty of the price of a litre of gas here. We also pay something like £125-£300 or so each year for a 'road fund licence' depending on the size of ya cages engine. All of these procedes are supposed to go into the road networks, but do they? bo!!ocks they do. The pollitricksters of this country are running it into the ground. But still, I love riding my scoot and scooterdoc is always here to help take of the pain of real life away
Certified Clinician
Post by looker on Nov 6, 2011 15:25:39 GMT -6
That's not a laptop it's a flatscreen T.V. I have a long commute to work every morning, and there is a small satelite receiver dish in the underseat storage box along with a signal decoder and DVD player. This way I can catch up on world news or watch a movie while riding my scoot at 90mph along quiet country lanes ;D
Certified Clinician
Post by looker on Apr 30, 2011 3:25:07 GMT -6
Hi guys, mainly a question for carburettors, should we come across symptoms of poor running. Things that I can think of (apart from hard to start and poor idle) are: stuttering when revving from idle, symptoms of a too large main jet (running rich), symptoms of a too small main jet (running lean), symptoms of a vac/air leak Pulling the plug to check it's condition is a common diagnostic, but was just wondering if anyone has had any of the above problems and what it turned out to be. My scoot runs fine, but thought it would be good to know about these things incase they happen so it could help with what to look for when fixing it. Mike
Certified Clinician
Post by looker on Apr 30, 2011 2:57:59 GMT -6
Hi Bong, I think all the black 'plastic' panels on my scoot are polypropylene and very soft. The bottom panel I just marked an oblong with a pencil and using a flexible metal rule/straight edge cut it out with a utility knife. Drilled a hole at each corner first just incase the knife wondered too far! For the fan cover I cut out every other fin with side cutters and trimmed the excess with the knife. Important not to use too much pressure I think with the knife so you don't break anything, especially near the centre. Mike
Certified Clinician
Post by looker on Apr 28, 2011 15:52:38 GMT -6
Well I can tell you that it has made a real difference to the temperature of the CVT cover, I can hold my hand on there after a long run without having to snap it back due to heat. Not a good picture but the only one I have to hand, inside the red circle and crudely drawn in in green is the outlet at the rear. And due to the fact that the only 115mm variator fan I could get that was'nt over priced is very much like this one, cgi.ebay.co.uk/perforance-Variator-GY6-125-150-Kymco-Vento-SYM-/180658011131?pt=UK_Motorcycle_Parts&hash=item2a100e7bfb#ht_1640wt_825I thought I had better do something to help that fan due to the smaller blades. CVT cover has been off a number of times and it sure looks cleaner than it did before this was done, and it's had close to a 1000 miles put on it. I thought the removal of the foam filter/screen at the intake of the CVT was a common recommendation? The one on mine was certainly full of crud and impeding airflow it was so bad. Believe me, you could not even touch the CVT cover before I did this.
Certified Clinician
Post by looker on Apr 28, 2011 4:27:46 GMT -6
Certified Clinician
Post by looker on Apr 28, 2011 4:14:09 GMT -6
Did this one a while back, www.scooterdoc.proboards.com/index.cgi?board=150cc&action=display&thread=2596and it's made a real difference, after a long run I can comfortably hold my hand on the CVT cover without getting burned, and it has'nt made a difference to the state of the inside. Infact, I think it also helps in blowing the crud out the back. More recently some simple hole drilling in the panel that is in front of the engine, also cut some material off the fan cover to open things up a bit there, All of this is guess work, with no temp gauge installed I can't tell if things are gonna be cooler, but if the CVT intake has helped cool things down, hopefully these other mods will help the engine. Cheers guys, Mike
Certified Clinician
Post by looker on Apr 27, 2011 16:37:49 GMT -6
Makes perfect sense
Certified Clinician
Post by looker on Apr 27, 2011 16:34:51 GMT -6
Did this to the bottom panel to hopefully pick up a bit more airflow onto the engine. Panel and a plastic louvered vent, hole cut in panel, vent fitted, panel back on scoot, might help add a little airflow up towards the engine.
Certified Clinician
Post by looker on Apr 27, 2011 16:18:30 GMT -6
Hi alley, I thought that may be what it's for, my carb starts to drop of the 'choke' after about 3-4 minutes maybe. It still requires a little throttle play to stop it dieing for 30 seconds or so. I'm sure when the scoot was new the enricher took longer to drop, so I actually put on a new one of these resistors today but it still operates the same, enricher is also new. Have adjusted the, what's it called?, the air fuel ratio screw? to get the best idle speed when it's warm. Once it's warm it idles @ about 1750-1800 rpm. May need to play around with it a bit more.
Certified Clinician
Post by looker on Apr 27, 2011 15:56:47 GMT -6
it's on the end of the green wire that comes from the auto enricher, it has 5w 5ohm on it. Could it be that it's a resistor to limit the current taken by the enricher so slowing it's function? Always wondered what it was, but my recent harness strip down revealed it's connection to the enricher. Mike
