LINHAI
by: bo - Feb 17, 2013 13:05:27 GMT -6
Post by bo on Feb 17, 2013 13:05:27 GMT -6
FRIST OF ALL I WONT TO THINK YOU ALLEYOOP FOR IHAD DONE GIVE UP ON GITTING A POST .I WAS OVER LOOKING THE NEW POST ICON.FRIST THING FRIST ILL GIT TO THE CLUCTH LATTER I DID WHAT YOU SAID TO DO TO GIT THIS THING TO START IT HELPED ADJ.VALUE AND ORING ON THE AUTO CHOKE.IT STILL START AND STOP 10-12 TIME WHEN IT 20 DERG.COULD THE GAS BE LEAKING BACK AND GOT TO CRANK IT TILL THE PUMP PUMPS UP PREASURE OR WHERE THE VALUE WERE NOT QUITE SHUTTING AND GOT BURNT A LITTLE AND LEAKING.IF I DO A COMPRESION TEST HOW MUCH PRESURE DO I NEED.IM GOING TO CK. VALUE ADJ. AGAIN MAKE SURE THEY ARE .004/.005 THOUSAND IN. THANK AGAIN FOR THE HELP BO
LINHAI
by: Alleyoop - Feb 17, 2013 13:42:01 GMT -6
Post by Alleyoop on Feb 17, 2013 13:42:01 GMT -6
Hi Bo, Good, that at least it is running HALF WAY DESCENT(HAHA). Q1. when riding around and giving it throttle speeding up and just riding it ANY PROBLEMS any farts or popping or backfiring or bogging when riding? Q2. At what RPMS does the SCOOT IDLE at when NICE and HOT? Q3. Does it hold the IDLE when coming to a stop or does it bounce up and down?
Do you have a ELECTRIC FUEL PUMP or a VACUUM operated Fuel Pump(Tank is in front and lower than the CARB) or PetCock(Tank is above the Carb under the seat or back of the seat)? Alleyoop
LINHAI
by: bo - Feb 17, 2013 15:29:00 GMT -6
Post by bo on Feb 17, 2013 15:29:00 GMT -6
ans to #1 no baskfire--no poping--nofarting real smooth #2 2,000 rpm bounch up/down maybe 25 to 50 rpm # 3 hold idel #4 vacuum pump--sits up front below carb i bought this 3mo ago and have only ridding it 14 mi. other than moving it from barn to grage 3 times just wont to git it the way it should be it has 1700 mi. on it.i can live with it the way it but would like for it to be right bo
LINHAI
by: Alleyoop - Feb 17, 2013 16:41:42 GMT -6
Post by Alleyoop on Feb 17, 2013 16:41:42 GMT -6
Ok sounds like everything is working good. You can check your compression
Do you have a Compression gauge? If so screw that in or if you have one with a rubber tip on it hold it in nice and tight then Hold the Throttle Wide Open and crank it you will see the needle move up until it stops moving. A motor with good compression around 150 above 150 is damn good. Alleyoop
LINHAI
by: bo - Feb 17, 2013 16:52:22 GMT -6
Post by bo on Feb 17, 2013 16:52:22 GMT -6
it will be mid wk. brfor i can git to it .should have done that when i had plastic off.ill git back as soon as i git it done bo
LINHAI
by: Alleyoop - Feb 17, 2013 16:59:47 GMT -6
Post by Alleyoop on Feb 17, 2013 16:59:47 GMT -6
You should at least be able to get to the plug without taking stuff off. WHICH LINAHI scoot do you have and what year. Alleyoop
LINHAI
by: bo - Feb 18, 2013 16:10:29 GMT -6
Post by bo on Feb 18, 2013 16:10:29 GMT -6
alleyoop i went back through it .ck vaules--ck spark plug--started it up let it get hot noticed the tack was jumpiing up and down 100 below 100 above 2000 so i look for a vacumn leak couldnt find one so i took the manifold off put hi-temp gook on it.that help but it dont make no differance if run air mix screw all the way in or very little cant tell by my tack i think it mess up on fine tuning.i can rib the motor up to 7000 rpm let go and it come back to 2000 and idel perfect bo
LINHAI
by: bo - Feb 18, 2013 16:24:48 GMT -6
Post by bo on Feb 18, 2013 16:24:48 GMT -6
forgot it has 150 lb of compression
LINHAI
by: Alleyoop - Feb 18, 2013 16:56:13 GMT -6
Post by Alleyoop on Feb 18, 2013 16:56:13 GMT -6
150 Compression is very good, also idle going up and down 100 is normal for a 1 cylinder motor. Now if the idle bounces a lot which is very noticeable like 500 or 1000 up and down then it is running very LEAN. Alleyoop
LINHAI
by: bo - Feb 18, 2013 17:26:29 GMT -6
Post by bo on Feb 18, 2013 17:26:29 GMT -6
the spark plug was a little blacker than what i like..just figure out why it wont start when its cold
LINHAI
by: bo - Feb 18, 2013 18:04:02 GMT -6
Post by bo on Feb 18, 2013 18:04:02 GMT -6
ok went back to garage started up ran 300 rpm fast idle wouldnt kick off so i gas up to 7000 rpm something hit the celin look and value stem come out of rim sometime it is best to stay in bed.now you going to tell me i got to pull the clutch- variator andall that stuff on left side to git wheel off. will reg value stem fit or do i got to git one that fit a scooter rim bo
LINHAI
by: Alleyoop - Feb 18, 2013 19:20:59 GMT -6
Post by Alleyoop on Feb 18, 2013 19:20:59 GMT -6
ok went back to garage started up ran 300 rpm fast idle wouldnt kick off so i gas up to 7000 rpm something hit the celin look and value stem come out of rim sometime it is best to stay in bed.now you going to tell me i got to pull the clutch- variator andall that stuff on left side to git wheel off. will reg value stem fit or do i got to git one that fit a scooter rim bo Q1. You started it and it IDLED at 3000 rpms? A. How long did it run at 3000 rpms after you started BEFORE you revved it up to 7000? About the Valve stem you should not have to take the wheel off to put in a new valve stem. Just get the wheel where you can clamp the tire in enough to slip in a new valve stem. About the Valve stem type I do not know the hole in the rim may be just like one in a car. Maybe Rich knows or someone else may chime. But Please let me know about the question I asked So I can then possibly point you to what is wrong or what to do. Alleyoop
LINHAI
by: bobf - Feb 18, 2013 19:27:20 GMT -6
Post by bobf on Feb 18, 2013 19:27:20 GMT -6
No need to take the wheels off to work on the stems. I used two C clamps, I think at least 6" clamp size, or maybe a 7" clamp size. Set them each about 6" away on each side of the stem. Let the air out of the tire if not already gone, start tuning them tighter and force the tire off the rim in that area. Then you can reach in and remove the stem or to replace the stem. I used the metal stems that can be ordered from the web. I don't remember the vender but maybe some one on here remembers who to buy from. They do bolt on so should not fly off. Once you have them installed and tested for tightness, not too tight or you damage the rubber gasket part and not so loose that they will rotate freely. Too me it becomes a judgement call.
Then you can start to remove the clamps and have a heavy mall handy, as you may need to pound the tire a bit to force it to expand over the rim edge. Once the tire seems set enough to hold air then start to fill the tire and actually run the pressure above the required pressure to force the tire to seat agains the rim and edges. Once sure the tire is properly seated then release the air pressure back down to what you want it to be.
This works on both the rear and front tires. You will be working in what ever space is free of the fender or frame. Not the most comfortable position to be in.
EDIT TO ADD: I put the clamps on the side of the tire on one side of the wheel, on the other side I put the clamp on the rim. That way I only pulled the tire from one side and had a bit more room for my hand to get in to tighten the nuts. To protect the rim you may need a couple of pieces of wood to clamp too. .
LINHAI
by: Alleyoop - Feb 18, 2013 20:01:11 GMT -6
Post by Alleyoop on Feb 18, 2013 20:01:11 GMT -6
LINHAI
by: bobf - Feb 18, 2013 20:23:33 GMT -6
Post by bobf on Feb 18, 2013 20:23:33 GMT -6
Thanks Allyoop, I have been looking for the source and just found them in my credit card records. So you beat me to it by 15 minutes at least, and I appreciate it. Hate it when I post as if I knew what I was saying then can't remember the source.
