Senior Clinician
Post by blu on Mar 26, 2020 11:39:28 GMT -6
My theory is they put that grease in there to hold the rollers in place during assembly. When I got a new variator, the rollers were held in place by a big gob of grease. I cleaned all the grease out, and assembly was much more difficult trying to keep all the rollers in place. Imagine an automated process, machine banging around, rollers bouncing out of their slots, what a mess. Sticking those rollers in a thick gob of grease would hold there during the process. Those rollers need to move smoothly with no resistance. Why pack them with grease.
Senior Clinician
Post by blu on Dec 14, 2019 11:13:02 GMT -6
Glad I have one of these. ![](https://i.postimg.cc/CZKvWWB7/CF250-172-MM-small.jpg)
Senior Clinician
Post by blu on Oct 30, 2019 9:30:13 GMT -6
I just paid $80 to find out my problem was a dirty air cleaner, so check that!
Senior Clinician
Post by blu on Oct 14, 2019 21:05:07 GMT -6
I've had a loud whining when rolling. By the time I get up to 45 it's screaming. As it gets hotter, it gets a little quieter. I don't know what it is, but I've been suspecting the belt. It's not very old, but it was a cheap one that came with the cheap drive kit, variator, clutch, and belt. It could be it. I'll buy a new belt in a couple months and replace. Nothing I can do about it right now, so I'll wait to get in there. Floor work is tough these days, I'm never too sure I'm going to get back up!
Senior Clinician
Post by blu on Oct 3, 2019 10:10:49 GMT -6
When I first got this Helix clone 4 1/2 years ago, I was getting 70mpg. It has slowly decreased. After the tadoo with the air cleaner last week, I guessed that makes sense, the more it got starved for air, the mileage would go down. The shop just removed the air filter, so I've been running with none. I assumed my mileage would increase. I just filled up and checked it, 56mpg! What can I do to increase my mileage? He went through the carb, so that's good. Why would I lose 15mpg?
Senior Clinician
Post by blu on Sept 26, 2019 7:55:03 GMT -6
I've had dirty air cleaners on everything I've ever owned, and none causes the problems this thing did, to the point I couldn't ride it. I've ordered a racing air cleaner that allows maximum air flow. The one that was on there was a K&N type with the oil saturating the cleaner. Never liked those things, by nature, they restrict air flow. Running without one now, but it's not dirty here, it will be ok for a week.
Senior Clinician
Post by blu on Sept 24, 2019 19:35:56 GMT -6
Took it to the shop. $80......dirty aircleaner. Lessons are expensive.
Senior Clinician
Post by blu on Sept 21, 2019 15:16:45 GMT -6
The one on the right came out of of it. The one on the left is a new one I bought off eBay a couple years ago. They don't look quite the same. After much ado (I lost the mixture screw behind the starter) I got it back together. It starts and idles just fine. But when I go to go down the road, it misses, and the hotter it gets, the worse it gets. I don't know what's going on. I'm going to have to take it to the shop and get raped. ![](https://i.postimg.cc/JyRdwFF8/20190921-165753.jpg)
Senior Clinician
Post by blu on Sept 19, 2019 18:06:24 GMT -6
Well, I just took the carb apart, everything looks good. Diaphragms are intact. No crud, passages and jets are clear. I'm wondering if the auto choke is working properly. I have a new one, maybe I'll put that in. You ever seen one fail? How did it behave?
Senior Clinician
Post by blu on Sept 17, 2019 15:28:29 GMT -6
Good to hear, thanks. It doesn't make any weird noises, so I don't think it's falling apart yet. Supposed to be less humidity this weekend, I might get some wok done on it, just to hot to do anything outside.
Senior Clinician
Post by blu on Sept 16, 2019 14:03:36 GMT -6
I've got about 11,000 miles on my Helix clone. Last spring I had a fuel problem. My "diagnosis" of the fuel pump showed it was good, but I messed up, it was the fuel pump ll alone. But since I thought the pump was good, I continued. Frustrated, I went down to the local scooter guy and had a chat. He said I might need to adjust the valves. He showed me the little butterfly adjustments. So I went home and messed things up. It's run good, except for a few failures, but it ran good and strong. It ran a little lean, but it ran good. The front butterfly (intake?) was almost all the way to the back, so I put it in the middle. Well, that didn't help. So I finally figured out it was the fuel pump, so I replaced it. Got it running, but it's run like crap ever since. If I warm it up and let it idle, it runs best with the front butterfly in the middle, but it foul plugs and gets terrible mileage. If I put it back where I found it, it lacks power and runs like crap. The other day I cleaned up the plug and put the butterfly almost all the way back and went to the park, about a 15 mile round trip. It was weak but ran, for a while, by the time I got home, it died right at my front step. I think I've really messed up the valves. So I'm going to order a new plug for it, think I'll take the carb apart and clean it. I should take a look at the valves, but I've never done that kind of work on such a small engine. So what do you mechanics think? Think I f'd up the valves?
Senior Clinician
Post by blu on Nov 28, 2018 17:09:43 GMT -6
Turns out, I was wrong. It's the pump. I ordered a cheap one, I'm poor!
Senior Clinician
Post by blu on Nov 27, 2018 9:39:40 GMT -6
The lines are good, like new. It's the fuel pump. I made a mistake when diagnosing, I checked the wrong line for vacuum. There's good vacuum at the pump, it's just not drawing any gas. Got a new one on the way.
Senior Clinician
Post by blu on Nov 26, 2018 11:02:55 GMT -6
What crack(s)? ![](https://i.postimg.cc/Nyr5j1k1/20181126-115938.jpg)
Senior Clinician
Post by blu on Nov 25, 2018 12:50:02 GMT -6
Just riding along on my CF Moto Helix clone, and it died. Got it home. There is no vacuum to the diaphragm fuel filter. Any idea?
