Post by roguesquid on Oct 31, 2012 0:32:09 GMT -6
Some smaller stuff can work as well, high flow air filter and bigger jets are relativèy cheap. I also think the engine we have is the long case due to the need of the transaxle. But this is a question for someone like Jim to be sure. Also perhaps octain booster might post an little spped but no top end increase.
engine swap
by: roguesquid - Sept 30, 2012 20:38:18 GMT -6
Post by roguesquid on Sept 30, 2012 20:38:18 GMT -6
has anyone tried to swap out the original ice-bear engine for another one. I am only assuming that one GY6 will work for another GY6 and if this is the case I might consider putting a Kymco GY6 in my trike. But I don't know if the bolts match
Post by roguesquid on Sept 30, 2012 20:32:51 GMT -6
some pictures would be nice.
regrets
by: roguesquid - Sept 30, 2012 20:31:03 GMT -6
Post by roguesquid on Sept 30, 2012 20:31:03 GMT -6
Had my first issue the other day that partially stranded me. The central point of the noises were coming from the fan on the right side. I heard some metallic grinding and wining sound then it stalled. I don't know if the fan can cause these symptoms or not . What I do know is that this has to be minor.
Alley sure would love to see this preventive maint you mention other then checking bolt and hoses as well as oil
regrets
by: roguesquid - Sept 14, 2012 17:29:33 GMT -6
Post by roguesquid on Sept 14, 2012 17:29:33 GMT -6
I know there are a few Chinese scoots here. I havent had much of any problems with my ice bear PST150-7t. I have had only one issues when I was driving on a very bumpy surface and I thing the coil of something in the ignition came off and with Alleyoops help I figured it out. I am one of those people who do allot of research. I hear some say Chinese scoots are crap and fall appart. I say you get what you pay for .
If you were to get another scooter, would it be ICE BEAR or Japanese?
Post by roguesquid on Sept 14, 2012 12:52:03 GMT -6
I put on the K and N filter I had and love the improvements. I didnt do the jets and left everything intact. I wanted to see how it responded to my shadetree jet work.
I tried to put the CDI in but It doesn't look to fit an anywhere on the right side of the scoot?
Post by roguesquid on Sept 14, 2012 12:48:39 GMT -6
how hard is to replace the gears ? I might be interested in the old gears.
Post by roguesquid on Sept 5, 2012 17:47:30 GMT -6
Where is the best place for quality jets? Rapid Jim?
Post by roguesquid on Sept 2, 2012 20:27:36 GMT -6
If the jet was too big would it Stall out on occasion when idling to acceleration ?
Post by roguesquid on Sept 2, 2012 20:19:25 GMT -6
Well actually i had said pst150-7t which is what it states MSO ? about the jets , I can't be sure the original was drilled .
Post by roguesquid on Sept 2, 2012 8:13:17 GMT -6
Post by roguesquid on Aug 30, 2012 21:19:17 GMT -6
What is the wire right off of the carb?
I already did the jets.but thanks
PST150-7T and it does have an air box with an good sized donut paper air filter. Was going to remove box and maybe the hose as well.
Post by roguesquid on Aug 30, 2012 21:14:29 GMT -6
Well OK, but what happens for tranny issues?
Post by roguesquid on Aug 29, 2012 13:58:47 GMT -6
I bought some upgrade performance parts for my trike. I bought an upgraded CDI , that is suppose to bypass the rev limiter etc.But i am not totally sure where to install it. I also bought an high flow airfilter . I was wondering do i just remove the who hole and old assembly from the carb? Or are people cutting the hose and using it as an adapter of sorts?
Post by roguesquid on Aug 29, 2012 13:53:21 GMT -6
I was wondering if there is an repair manual out there for the PST150-T or there abouts. I know hanynes has onefor chinese bikes but is there one for the trikes?
