Post by datonamanmike on Aug 7, 2013 20:14:47 GMT -6
it does not use a battery its a 2 stroke moped that makes its volts with a magneto (bad spelling??) this regulator is supposed to regulate the volts so it don't blow bulbs cause the more rpm the more volts with the BBK it makes more rpm hence more volts
Post by datonamanmike on Aug 7, 2013 15:56:31 GMT -6
I have this voltage regulator I want to put on my tomos moped that runs on a mag. meaning it uses no battery I keep blowing light bulbs a LOT the bike does have a 70cc kit and I think by going faster turning more RPM im producing too much voltage but I don't know where to install this can anyone show me how and where to install this?? Attachments:
Post by datonamanmike on Aug 6, 2013 10:52:23 GMT -6
im with KZ on this one ......
Buy them. I guarantee complete satisfaction. you can now get big bore kits for these
Post by datonamanmike on Aug 6, 2013 10:47:45 GMT -6
well said KZ and congrats on your milestone I feel the same about china bikes properly taken of and not beat to death I feel they will last well into the 20 to 30,000 mile range maby more
Post by datonamanmike on Jul 29, 2013 19:14:08 GMT -6
yes KZ thank you that's what I thought I used to have the one you picture it was a baron motor cycle I converted it like yours but with a clutch and foot rear brake loved it could do wheelies kept up in traffic went like 60 but here in florida a moped must have pedels I put like 3 motors on it first a 90cc then 110cc and it still runs with a 125cc my nefew has it
Post by datonamanmike on Jul 29, 2013 16:59:55 GMT -6
HELLO FRIENDS I have a 2012 SSR lazer5 moped with a 72cc kit I have smaller rear sprocket no limit CDI this is it highstylemotoring.com/MOPED.html if you cant click on the link copy it into your browser the bike runs very well I realy like it it runs about 45MPH or so the speedo says im going 50MPH but I know better my problem is it takes off like a snail I mean realy slow once it gets to about 3000RPM then picks up real good from zero to 3000RPM snails pace im having to pull over into the bike lane (when there is one) to let cars by what can I do ....a bigger sprocket in the front ?? if yes can some one point me to some one that sells em iv just hit 500 miles so im going to adjust the valves and check the timing the carb has been properly re jetted and im running the stock air box the moter is just like a Honda clone motor horizontal except the motor has pedals thanks for all the help in advance one last thing to add it is a 4 stroke motor Read more: scooterdoc.proboards.com/index.cgi?board=talk&action=display&thread=8259#ixzz2aTiRgD61
Post by datonamanmike on Jul 29, 2013 16:56:16 GMT -6
USE "JETS R US" GREAT PEOPLE great site good prices fast shipping lots of good info on there site www.jetsrus.com/ if you cant click on the link just copy and paste to your browser
Post by datonamanmike on Jul 29, 2013 16:51:29 GMT -6
Post by datonamanmike on May 18, 2013 16:21:09 GMT -6
ok guys I can tell ya bout my moped I have a lazer5 4 stroke 2012 72cc kit it has real good top speed now 65kph/40mph thing is my prob is 2 fold at top speed im hitting the rev limiter & take off is kinda slow now I already have a 37 tooth for the rear but I would like to get a front one that will give me a little more take off speed I know the 37 tooth rear will get me off the rev limiter but I want a little more take off thanks for your intrest if you would like to know more bout the lazer5 I can send link
Post by datonamanmike on May 16, 2013 20:58:49 GMT -6
I HAVE A CHAIN DRIVEN MOPED can someone please set me straight I always thought is was smaller rear sprocket = more top speed bigger rear sprocket = more take off speed smaller front sprocket=more top speed bigger front sprocket= more take off speed am I right or is it the other way around???
Post by datonamanmike on May 3, 2013 15:58:37 GMT -6
thank you KZ
Post by datonamanmike on May 3, 2013 15:39:03 GMT -6
im not realy looking to increse my mopeds capabilities im trying to find out if when im cruising along at top speed will a smaller rear sprocket lower or increse my rpms
Post by datonamanmike on Apr 30, 2013 20:35:57 GMT -6
i have a simple question i have a moped that is chain driven my question is if i put a smaller rear sprocket on it to gain some top end speed will this increase or decrese engine RPM? i would also like to know the same thing about the front sprocket to keep some low end speed . but will making the front sprocket bigger increse engine RPM or lower RPM ? thank you in advance
