auto choke?
by: scooterhater - Aug 25, 2014 8:57:24 GMT -6
Post by scooterhater on Aug 25, 2014 8:57:24 GMT -6
You got it pal, there is no temp sensor involved. The timing on the plunger coming out is dependent on the variances of voltage between bikes and that particular auto-choke. Typical Chinese slap dash engineering. So some of them shut off early, some late, and some just by luck are spot on. Don't ya love it? HAR! Rich yup definately not a precision enginered control
Post by scooterhater on Aug 25, 2014 8:48:52 GMT -6
one thing about a scooter is that you will never get bored. there is always something to do to one
auto choke?
by: scooterhater - Aug 24, 2014 20:32:06 GMT -6
Post by scooterhater on Aug 24, 2014 20:32:06 GMT -6
gy6 50cc, I know it has resistance and that moves the needle, is this circuit tied to a temp sensor, how does it know when the engine is warm enough. may be a dumb ? but I just like to know what makes something work. re read the tutorial on the choke and it looks like it works strickly off of current flowing thru it and the material around the resistance heating up.
Post by scooterhater on Aug 24, 2014 12:26:51 GMT -6
you won't like it, they are maid in china
hooray
by: scooterhater - Aug 24, 2014 12:21:18 GMT -6
Post by scooterhater on Aug 24, 2014 12:21:18 GMT -6
a big hooray and thanks to the admin and sponsors. WHAT A GREAT SITE AND RESOURCE
Post by scooterhater on Aug 24, 2014 12:16:28 GMT -6
update: pulled carb and drilled out plug over a/f screw. while I had it off went ahead and opened bowl and removed jets and cleaned, everything looked ok. I had a new enricher so compared it to existing one and the old one seemed to be stuck about half way. reinstalled carb w/ new enricher and adj. a/f. idles and runs good and starts everytime warm or cold engine.probaly didn't need to open up the carb but I had it off so figured now is the time to check. maybe in another 20 years of this I'll be almost as good as Alleyoop. and MAYBE NOT
Post by scooterhater on Aug 20, 2014 8:04:25 GMT -6
Did you try .002" intake and .003" exhaust. I'm just pulling your chain...I just want to see how many times I can get you to set your valves. Have you tried .009" and .003 Angstrom? Yeah, try that, just once more. on the 3rd try I went ahead and adj. that 3rd valve that sits off to the side by it'self and now all is fine!!!!!!
carb info
by: scooterhater - Aug 19, 2014 8:25:56 GMT -6
Post by scooterhater on Aug 19, 2014 8:25:56 GMT -6
gmw rx50, gy6 50cc engine. posted earlier about a starting problem and alleyoop says it is running lean. am sure that is the problem because now the idle is up and down. the air/fuel screw is plugged and I will atempt to drill it out. if I screw this up what carb do these engines take? the carbs are not very expensive so it might be a good idea to have one on hand. before I work on the carb I will check for any air leaks
Post by scooterhater on Aug 17, 2014 16:44:08 GMT -6
thx alley will adj. the fuel mixture tommorrow
Post by scooterhater on Aug 17, 2014 16:14:33 GMT -6
reset valves to .002, started good ran at top speed all normal. shut off and had to wait 3/4 minutes before it would restart. it does this consistantly. do I need a new enricher?
Post by scooterhater on Aug 17, 2014 9:17:11 GMT -6
Check the ENRICHER, take it off when COLD and lay it on it's side and cover the hole with your thumb and start the motor. Now keep you thumb on the hole and watch the Valve on the ENRICHER and see if it EXTENDS out about 1/4 of an inch in about 3-5 minutes. Then shut the motor off and watch the enricher and see how long it takes for the Valve to RETRACT. Alley enricher extends in about 3-4 minutes, takes the same amount of time to retract
Post by scooterhater on Aug 16, 2014 20:42:31 GMT -6
more observations. started and let it idle for 5 minutes,shut off and tried to restart but wouldn't start. let sit for 5 minutes and started and idled good, acceleration normal. shut off and tried to restart,wouldn't start. let sit a few minutes and started right up. will still check valves, any other suggestions if valve adj. ok
Post by scooterhater on Aug 16, 2014 19:21:40 GMT -6
Post by scooterhater on Aug 16, 2014 8:11:23 GMT -6
gy6 50cc engine, starts good on cold engine and idles down after warm up. runs out good. when you try to restart on warm engine it tal kes an excessive amount of cranking to start. once it starts idles and runs good and reaches max speed and rpms. did routine maintenance about a 100 miles ago including valves, set at .003. the starting problem just surfaced. what do I need to check thx Jim
Post by scooterhater on Jul 28, 2014 19:43:46 GMT -6
thx alleyoop, that was a great explanation. with what I've experienced so far tells me right where I need to be. of course if you listen to LUKE I'll never get anywhere because it's a chineese scooter(rofl)
