Doc's Anything Goes
Post by twodogsnme on Jul 12, 2020 12:42:56 GMT -6
Hi everyone...i have a 2020 Icebear 150cc vision that I have changed all exterior bulbs to led. All was working fine..til 1 day the electric start button wouldn't start the scooter.so I kicked it over...i have all lights/horn except brake lights high/low beam and electric push button start. Any thoughts?
Doc's Anything Goes
No spark
by: twodogsnme - Mar 9, 2017 13:51:44 GMT -6
via mobile
Post by twodogsnme on Mar 9, 2017 13:51:44 GMT -6
Help please...i have a 13 TaoTao Lancer 150cc. I have no spark..it turns over fine. The stator(6 coil) is new..less than 1000mi..have a multi meter that i dont know how to use..too many options. Have read and understand how to test ohm and ac..but my multi meter has ACV 500/200..ohm has 20m, 200k, 20k, 200, 200. Can someone tell me whoch i should for both ACV and Ohm? Thanx
Doc's Anything Goes
stator
by: twodogsnme - Jun 16, 2016 17:01:20 GMT -6
via mobile
Post by twodogsnme on Jun 16, 2016 17:01:20 GMT -6
What is the difference btwn 6...8...11 coil stators?..Thanx in advance fer the info..
Doc's Anything Goes
Post by twodogsnme on Mar 26, 2016 19:13:20 GMT -6
I installed a racing starter clutch on my Tao Tao 150cc Lancer...can't get it to start now..checked all electrical connections..all r good..my question is ..do I also need to get high torque starter? When I hit start switch I get a whirring sound..but no turn over..( can't send video alleyoop..phone doesnt have YouTube)..any help will b gratefully appreciated
Doc's Anything Goes
Post by twodogsnme on Mar 20, 2016 10:46:11 GMT -6
Took kick start off..was making a rattling noise..looks like it wasn't aligned correctly n kinda screwed up the gears
Doc's Anything Goes
Post by twodogsnme on Mar 20, 2016 9:36:03 GMT -6
How do I post video on here?
Doc's Anything Goes
Post by twodogsnme on Mar 19, 2016 10:08:27 GMT -6
Sorry bout the delay..work n life..I can't get it to start at all..when I hold brake n hit starter button I hear the starter spinning. It won't turn the starter clutch at all..help please...also installed free flow air filter ( uni clone )...
Doc's Anything Goes
Post by twodogsnme on Mar 4, 2016 18:23:46 GMT -6
It runs just fine when it'll start..replaced starter/ solenoid..starter works well..must b internal issue? Any thoughts? Can't get it to start now..just get the starter whit n click when switch released..please help!!!..THANK YOU
Doc's Anything Goes
Post by twodogsnme on Feb 22, 2016 9:53:03 GMT -6
I'm having a hard time starting scooter. When it's first started I get a whirl sound. It cranks n cranks..n eventually it will fire. When the engine has been run for a while it starts with one push of start switch. I have just replaced starter starter solenoid stater coil and plug wire. Any thoughts? Also just put on performance mmuffler and head pipe. Thank you for any info
Doc's Anything Goes
stator removal
by: twodogsnme - Feb 17, 2016 17:23:50 GMT -6
via mobile
Post by twodogsnme on Feb 17, 2016 17:23:50 GMT -6
Alright scooterphiles..I have removed flywheel and now the stator will not budge..any thoughts?..tried a light pry 28th screwdriver but it didn't even move a millimetre!!...please help me!! Thank you
Doc's Anything Goes
Pilot jet id
by: twodogsnme - Jun 14, 2015 11:13:12 GMT -6
via mobile
Post by twodogsnme on Jun 14, 2015 11:13:12 GMT -6
jct842...what a grand idea!! Duh on my part!!...gonna do just that on Mon.. Out ridin today..thanx n keep the rubber down
Doc's Anything Goes
Pilot jet id
by: twodogsnme - Jun 13, 2015 20:36:49 GMT -6
via mobile
Post by twodogsnme on Jun 13, 2015 20:36:49 GMT -6
I bought a yerfdog 26mm carb n replaced main jet w/110..got lots of mid n top end now but bogs at start off..it was suggested by Alleyoop that my pilot may b too big..pulled it out only to find NO numbers on it anywhere...does anyone know what size pilot jet comes standard in this carb? Looked around online but to no avail..any help/suggestion would b appreciated..keep the rubber down
Doc's Anything Goes
Post by twodogsnme on Jun 9, 2015 23:27:10 GMT -6
Alright scooter folk..need some help..I have a fuel line that runs from tank to silver contraption.. Filter in between..the fuel line runs thru this thing then down to carb..it(thingy) also has two lines that run to intake manifold n topside of carb..they r TD off past thing..what is this? N can I get rid of it n install a on/off petcock? If yes what do I do w/extra lines that run to intake manifold n carb? All replies will b appreciated..keep the rubber down
Doc's Anything Goes
A/F mixture
by: twodogsnme - Jun 5, 2015 6:59:02 GMT -6
via mobile
Post by twodogsnme on Jun 5, 2015 6:59:02 GMT -6
Thank you
Doc's Anything Goes
A/F mixture
by: twodogsnme - Jun 3, 2015 0:27:15 GMT -6
via mobile
Post by twodogsnme on Jun 3, 2015 0:27:15 GMT -6
Alleyoop..took enricher off per post here at scooterdoc..used gasket material to block holes n removed needle "housing"..even used gasket material to block hole where needle assy goes..no leaks..checked twice..gonna get smaller pilot jet n c how that goes..will post more later.. Got any recommendations fer cdi n coil setup? What about those auto adjust cdi units? Any good? If so can u post a link to one n the coil to match please? Thank you ...keep the rubber down!!
