Senior Clinician
11,000 Miles and Counting...
Post by bhinch on Jan 24, 2016 17:23:54 GMT -6
Image did not post..sorry..will try again...
Senior Clinician
Post by bhinch on Jan 24, 2016 17:23:10 GMT -6
Here is the one that I used....
Senior Clinician
Post by bhinch on Jan 24, 2016 17:15:37 GMT -6
You might have a bad blocking diode, which controls the R/R to charge the battery. It is like a one way valve and is close to the R/R. I have had the same problem with my scoot. Finally found a diode that would replace the one on my scoot, does not look like the oem.
Senior Clinician
Post by bhinch on Jun 29, 2015 14:46:03 GMT -6
The wheel is determined by which engine you have. I think the 244cc has one style and the 257cc has another style. I replaced my rear wheel almost 4 years ago and I lucked out to get one off Ebay. The 257cc uses the 260 scooter rear wheel. Most of the time the rear wheel nut comes loose and the wheel moves side to side. This removes the inner splines for the axle and ruins the wheel. I always check the rear axle nut every time I think about it.
Senior Clinician
Post by bhinch on Oct 13, 2014 10:03:43 GMT -6
I am 66 yrs young myself. The front tires last normally 2x or 3x longer than the rear. I use my local Yamaha shop for tire mounting, I just tell them the tires are off a Yamaha scooter. Enjoy...
Senior Clinician
Post by bhinch on Oct 11, 2014 8:20:01 GMT -6
I use Avon Strykers....all tires only last around 2500 to 3000 miles, it you regular check air pressure. The low profile hides the low pressure of the tire. I have installed 4 sets in 11,500 miles and 6 yrs of service. Enjoy the ride...
Senior Clinician
Post by bhinch on Oct 9, 2014 4:35:40 GMT -6
I have 11,500 on my scoot. 2008 Roketa...love it...
Senior Clinician
Post by bhinch on Sept 29, 2014 8:34:43 GMT -6
The rear axle nut must be tight and it should be checked everytime you think about it. I use blue loctite and do not turn the nut after using the loctite. That will defeat the loctite and it will come loose again. I move the wheel/tire left to right to check for movement.
Senior Clinician
Post by bhinch on Sept 22, 2014 9:39:27 GMT -6
I had the same problem a few years ago and it was the R/R. Replaced it and everything was back to normal. Enjoy..
Senior Clinician
Post by bhinch on Sept 19, 2014 11:29:41 GMT -6
I had to change my r/r last year. It was located on the right side behind the rt rear body panel. I remove the seat...the inside panel...trunk holder...trunk.. try and remove just enough to lift the side panel and r&r the R/R. I could see the R/R from underneath the panel.
Senior Clinician
Post by bhinch on Sept 5, 2014 4:40:09 GMT -6
I installed HID's about 4 yrs ago. I used H4..9003..5000K..Hi/Lo w/relays.. I love them. Enjoy the ride...
Senior Clinician
Post by bhinch on May 9, 2014 5:44:45 GMT -6
Welcome...I would adjust the valves and see if that helps. My 250B (257) has over 11,000 miles and I have adjusted the valves one time. Runs great.... intake .004 exhaust .006 enjoy your ride...
Senior Clinician
Post by bhinch on Apr 24, 2014 17:35:58 GMT -6
I use plexiglass cleaner used on small aircraft windshields. I get it from Aircraft Spruce. The website is www.aircraftspruce.com Enjoy your ride...
Senior Clinician
Post by bhinch on Mar 28, 2014 16:10:27 GMT -6
I installed a manual choke from the forums and it has worked great for over 5 yrs. Try it...
Senior Clinician
Post by bhinch on Mar 23, 2014 9:36:03 GMT -6
The motorcycle shop will do the exchange, just don't tell them it is for a Chinese scooter (no matter what make). The 10/12/13 inch tires are very hard to remove and install. The new tires are very stiff and even when done in 100 plus degree summer days. Just my 2 cents...
