Senior Clinician
Hello from Finland!
Post by jalat on Sept 12, 2011 22:29:43 GMT -6
Thank you Cruiser
Senior Clinician
Hello from Finland!
Post by jalat on Sept 12, 2011 3:33:49 GMT -6
It is paper. Same filter which is used in honda helix.
Senior Clinician
Hello from Finland!
Post by jalat on Sept 11, 2011 23:16:04 GMT -6
How often should one change airfilter? Mine is 9200km (5700 miles) used already.
Scrooter Jonway YY250T cfmoto Honda reflex colen
Senior Clinician
Hello from Finland!
Post by jalat on Sept 2, 2011 5:29:49 GMT -6
Is moskito 50cc ? If it is then I would not recommend to put HID.
But if you do put HID, take the power from battery and use relay. Then HID goes on and off just like your old headlight. Do not use old wires for HID. Do it good and take heavy wire from battery.
Senior Clinician
Hello from Finland!
Post by jalat on Aug 23, 2011 21:50:42 GMT -6
Ok we got the stock muffler working and it didn't get much louder. We removed all the wool of and all the loosen parts. Pipes and stuff we welded back. Maybe this works 1-2 years longer. Chrome cover did cover up all weldings. So it is almost like a new. But anyway thank you guys for your links. Maybe they are helping to someone else or me later.
Senior Clinician
Hello from Finland!
Post by jalat on Aug 23, 2011 1:11:17 GMT -6
I can't believe that the muffler is final after 3 years and 5500 miles. I guess here we see the Chinece quality.
Senior Clinician
Hello from Finland!
Post by jalat on Aug 22, 2011 22:56:27 GMT -6
Wow! That is cheap. Have to contact them if we don't get this original fixed. Thank you Cruiser
Senior Clinician
Hello from Finland!
Post by jalat on Aug 22, 2011 22:47:57 GMT -6
Thank you thescootersolution. But there is one problem I'm from Finland and there haven't been dealer for these Chinese scooters for for 2-3 years. So I need to order every spare part from USA or Ebay or from some dealer who will ship it to Finland. That's why I ask for different internet shops and hopefully somebody send it to Finland.
Senior Clinician
Hello from Finland!
Post by jalat on Aug 22, 2011 12:04:22 GMT -6
There is everything loose in my scooter muffler. It is keeping annoying rattling noise all the time. We will try to open it and empty all loosen parts. Then weld it back into a one piece if it is possible.
But if it is not possible to fix it, then where i can buy cheap stock muffler for yy250t scooter? (cfmoto engine)
Senior Clinician
Hello from Finland!
Post by jalat on Aug 18, 2011 23:35:32 GMT -6
Senior Clinician
Hello from Finland!
Post by jalat on Aug 18, 2011 13:53:31 GMT -6
FYI!
Cruiser you are right. I just order CN250 variator and the measurements were exactly same as my stock variator. 5" variator fan is the one for these YY250T (cfmoto) scooters.
Senior Clinician
Hello from Finland!
Post by jalat on Aug 18, 2011 13:50:35 GMT -6
Senior Clinician
Hello from Finland!
Post by jalat on Aug 18, 2011 12:18:46 GMT -6
Senior Clinician
Hello from Finland!
Post by jalat on Aug 18, 2011 11:29:14 GMT -6
I tested new clutch and bell couple of days and noticed that there is a lots of rhythmic vibration when I reach certain speed. In this case 50 mph. That vibration did not exists with old clutch. I have driven about 150 km with that new clutch. Should it vibrate like that at first. I remember to read somewhere that new clutch may feel weird at first 500-800 km. Then it is worn to have good contact. Is this true?
Senior Clinician
Hello from Finland!
Post by jalat on Aug 18, 2011 9:53:05 GMT -6
