Senior Clinician
Post by sunlproblems on Dec 31, 2011 23:26:34 GMT -6
could be a bad pump or pet cock valve
Senior Clinician
Post by sunlproblems on Oct 18, 2011 1:37:58 GMT -6
first off try a paper clip into the wires that are hooked to the brake switch to see if the switch is bad then pull the seat box out and ground the selanoid to see if it starts then start at battery with an ohm metter and look for current on the selanoid thats where i would start out at
Senior Clinician
Post by sunlproblems on Oct 9, 2011 22:37:14 GMT -6
wd 40 works good to spray the wires and cannections with it stands 4 water deterrent 40 different uses try that
Senior Clinician
Post by sunlproblems on Oct 8, 2011 17:19:31 GMT -6
do the valves again they closed back up mine did
Senior Clinician
Post by sunlproblems on Oct 8, 2011 17:10:51 GMT -6
ya its the starter gear hitting off the kick starter for sure idle way to high
Senior Clinician
Post by sunlproblems on Oct 6, 2011 19:32:24 GMT -6
its okey about mid range check your fuel pump petcockvalve should be the issuie
Senior Clinician
Post by sunlproblems on Oct 6, 2011 19:24:16 GMT -6
they look like they go in the snow as well like to check them out send out a link on them please
Senior Clinician
Post by sunlproblems on Sept 28, 2011 22:59:04 GMT -6
check the valves again you may not have tightened up the retaining bolt tight enough
Senior Clinician
Post by sunlproblems on Sept 27, 2011 6:11:50 GMT -6
u need a low amp batt. charger
Senior Clinician
Post by sunlproblems on Sept 24, 2011 19:10:15 GMT -6
i dont think so but put it on see if it does if not clean it up ship it back
Senior Clinician
Post by sunlproblems on Sept 18, 2011 2:36:28 GMT -6
i did mine by moveing the cable around i had a 150 that i would open the seat by pulling on the cable from under the plastic on my 250 i zipped tied my cable to make the seat open easier some one aid on here you can move them up or down by adding or removeing shims from the bracket hope this helps you out
Senior Clinician
Post by sunlproblems on Sept 18, 2011 2:31:43 GMT -6
i would check the valves to see if they need to be ajusted
Senior Clinician
Post by sunlproblems on Sept 9, 2011 21:11:12 GMT -6
yes clean the carb out if its been sitting
Senior Clinician
Post by sunlproblems on Sept 9, 2011 21:06:59 GMT -6
all chinese scooters .com or scrappy may have it
Senior Clinician
Post by sunlproblems on Sept 9, 2011 21:05:15 GMT -6
when i lock my steering if i turn 1 click to fair my lights come on did u do that?
